Fuel Pump noisey
Old Sep 25, 2006 | 03:33 PM
descivic's Avatar
descivic
Default Fuel Pump noisey
Ok so I just replaced my fuel pump last night, I never got around to putting the back seat on.. Is that thing supposed to be that damned Loud? or does the seat just muffle it So before I never noticed it..
Old Sep 25, 2006 | 04:08 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Is it just an OEM pump? My Walbro 255 lph pump is noisy as hell, especially with a full tank of gas.
Old Sep 25, 2006 | 04:28 PM
descivic's Avatar
descivic
no Its a pump that I bought from Autozone.. Master or something.. MY friend works there and I got it for cheap$$ but Its noisey as balls. And It sounds like its struggling or something?? I dunno
Old Sep 25, 2006 | 06:21 PM
Provocateur
On permanent hiatus
It is probably noisy because it is cheap junk. Stick the seats on and see if the noise gets muffled, but I think it will just naturally be louder than an OEM pump because of build quality.
Old Sep 26, 2006 | 01:09 PM
descivic's Avatar
descivic
True dat.. It was pretty cheap, just a temp solution until I buy the Walboro, Although Those pumps are capable of pumping 255 lph will I have to much fuel pressure or will It just dump the excess fuel back into the return line??
Old Sep 26, 2006 | 01:14 PM
t3t4delsol's Avatar
t3t4delsol
you will only get the fuel pressure that you fpr is set at
Old Sep 26, 2006 | 01:57 PM
Provocateur
On permanent hiatus
You will have a higher fuel pressure if you don't have anything to turn it down with. The stock FPR can't keep up with the extra volume of fuel coming through the rail to regulate it to stock pressure.
Old Sep 26, 2006 | 07:10 PM
t3t4delsol's Avatar
t3t4delsol
really? i thought the stock fpr was limited in pressure
Old Sep 26, 2006 | 07:27 PM
Provocateur
On permanent hiatus
It can't regulate the amount of flow coming through the rail to stock pressure. I still have a stock FPR on mine and my injector duty cycle is abnormally low because the fuel pressure is so high.
Old Sep 27, 2006 | 07:13 AM
t3t4delsol's Avatar
t3t4delsol
550cc?
