auto-to-manu
i want to convert my dc2 from automatic to manuel transmission. i need to know what parts i would need. i know i need the transmission, pedals, shift linkage. what else! which is better cable clutch or hydrolic clutck?
you will also need all clutch parts including flywheel as urs has a torque converter on just remove and install all clutch parts including flywheel bfor fitting gear box u might need to change ur ecu to a manual version as well.cable or hydraulic clutch well depends whats fitted to urs but hydraulic automatically adjusts to wear on ur clutch friction disc
