View Poll Results: s200 or s300
s200
0%
s300
3
100.00%
Voters: 3. You may not vote on this poll
hondata question??
Old Nov 15, 2006 | 08:35 PM
daddiodanger's Avatar
daddiodanger
bad mo fo
Default hondata question??
i've been trying to figure out what is the difference between the s200 and the s300. the s200 with the accesories can run a couple hundrend dollars over the s300 which has the same stuff, and its USB compatible. it just doesn't look as cool as the s200s little blue box.
i'm leaning toward the s300.
so whats everyones preference?
Old Nov 15, 2006 | 09:04 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Crome. :run:
Out of the two, the S300 seems to be the better choice. With the S200, you have to purchase the rom editor, emulator, boost feature, yada, yada, yada. The S300 comes as an all inclusive package with everything you need to tune yourself (minus wideband and laptop). I know that some of the vendors on h-t can get a killer deal on the S300. :shhh:
Old Nov 16, 2006 | 10:39 AM
Snoopy's Avatar
Snoopy
been there done that
s200 still requires burning chips. s300 is fully contained inside the ecu and you make changes with a laptop connected by usb cable. the changes go into effect almost immediately.
Old Nov 16, 2006 | 03:48 PM
daddiodanger
bad mo fo
coolsville..looks like there is a pretty simple decision here.
i'm looking into crome, also.
a buddy has one, and i saw some kind of chip burner under his desk, which seems interesting to me, however i have a lap top and that seems so much easier to use.
