Are VTEC engines more modificated than Type-R engines?
Old Sep 17, 2006 | 07:13 AM
B18C4-VTEC's Avatar
B18C4-VTEC
Default Are VTEC engines more modificated than Type-R engines?
i've been told VTEC engine are more modificated... Is that possible???
Old Sep 17, 2006 | 07:36 AM
torn_phoenix's Avatar
torn_phoenix
you would
modificated? or modified?
Old Sep 17, 2006 | 08:38 AM
gsr converters's Avatar
gsr converters
i thought type r's were vtec
Old Sep 17, 2006 | 09:01 AM
FooD2000's Avatar
FooD2000
Still Water
Type-r engine does come with a vtec head (b18c5).
Here's a list of all the engines and it's hp ratings: http://www.angelfire.com/extreme4/we...er_ratings.htm
Old Sep 17, 2006 | 01:00 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Yes, modificated, from the greek origin modifcious modicus.
Old Sep 17, 2006 | 01:16 PM
Snoopy's Avatar
Snoopy
been there done that
i'll try to give you a straight answer. itr engines are vtec. when compared to b18c's from gsr's, from the factory itr engines, b18c5 and b18c, have a different casting head that has a mild port job, bigger cams, higher compression, lsd short ratio tranny, and a range of other things. in short, itr engines are more modified than other b series vtec engines.
Old Sep 17, 2006 | 03:46 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Moved to Engine Tech & Tuning...
Old Sep 17, 2006 | 06:51 PM
Buyimports2's Avatar
Buyimports2
Do your parents make you wear a helmet when you go outside?
Old Sep 18, 2006 | 03:49 AM
B18C4-VTEC's Avatar
B18C4-VTEC
Maybe... Do your's?????
Old Sep 18, 2006 | 06:19 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
One of the worst threads ever. :closed:
