overheating help!!! [94 Civic w/ 2000 B18B1]
Old Sep 29, 2006 | 03:41 PM
EricsLSHonda's Avatar
EricsLSHonda
Default overheating help!!! [94 Civic w/ 2000 B18B1]
i have a94 honda civic with a 2000 ls motor and ive had it about a year and i recently started driving it and some things broke like usual when driving a car but still the car ran great. recently it started overheating and i replaced the thermostat, it doesnt overheat really bad i can driove it for 10 minutes straight and itll go little past half. but what happen was i drove it and one day i stopped at my buddies and popped the hood and i had no coolant it went into the over flow and sprayed out the overflow cap. so i drove it home and changed the therm. and put new coolant in. went for a ride still overheated a little. my question to anyone is, is it the water pump which is what i think, and if it is is it easy to change?
Old Sep 30, 2006 | 06:08 AM
m735is's Avatar
m735is
You'll have to remove the cover on the timing belt and look for coolant out of the pump weep hole.
First I would bleed the cooling system to make sure all of the air is out. Maybe do a compression check if you ran without coolant for any length of time.
Is the radiator cap fairly new?
Old Sep 30, 2006 | 05:25 PM
EricsLSHonda
it didnt over heat a lot and i still had some fluid so it should be fine i replaced the thermostat and its fine now but i still wanna chnage the water pump. car runs great and starts up fine i dont think nething is wrong nemore since i chnaged the thermostat
it didnt over heat a lot and i still had some fluid i only drove it for bout 10 minutes but i chnaged the thermostat and it runs fine hasnt overheated and yes the radiator is brand new.
Old Oct 2, 2006 | 07:39 AM
primetime's Avatar
primetime
Have you checked you coolant lines to see you may possible have a leak in one of them!!
