will a B16A2 computer work on a.....
Old Sep 13, 2006 | 04:06 PM
jonathan_in_ky's Avatar
jonathan_in_ky
Default will a B16A2 computer work on a.....
We are doing a conversion on a 98 civic. We are changing the 1.5 to the B16A. We are wondering if a computer with the numbers: B16A2 will work on the B16A engine?
Thank you in advance and have a great day!
Old Sep 13, 2006 | 04:14 PM
delsol161's Avatar
delsol161
it would prolly work... but i believe the fuel curves are slightly different. not completely sure.
Old Sep 13, 2006 | 04:39 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It will work just fine, but the 99-00 Civic Si is OBD2b, so it won't plug into your 98 OBD2a harness...assuming that is where you are getting it from. If it is from a Del Sol B16A2, it will just plug in.
Old Sep 13, 2006 | 05:33 PM
jonathan_in_ky
Does anyone know what computer I DO need for the B16A engine?
Old Sep 13, 2006 | 06:00 PM
delsol161's Avatar
delsol161
ummm... the factory/JDM ecu...
Old Sep 13, 2006 | 06:22 PM
jonathan_in_ky
Thank you. I am doing this conversion for a friend and am just not too familiar with Hondas yet. Hasn't been too bad getting it bolted in, just down to all the "fun" stuff. lol
The car is a 98 civic that had a 1.5 now It has the 1.6 (B16A) in it, I have the clutch conversion kit, just lacking the computer and am wanting to make sure we purchase the correct one, as there are no returns on them.
Old Sep 13, 2006 | 07:40 PM
stereo's Avatar
stereo
it all depends on which B16A2 if it's a USDM 99-00 Si it will work fine but will not plug into the 96-98 because it's OBD2a and the 99+ are OBD2B the plugs will fit but the pin out is diffrent so either a adapter is used orreplace 1 plug and repin the other 2 plugs . also the 99+ cars the EVAP system is diffrent so CE might come on if you dont swap those parts.
Old Sep 13, 2006 | 08:34 PM
Civic2Scooby's Avatar
Civic2Scooby
whoa whoa whoa.......do you mean b16a...as in first gen...cable b16a....
Old Sep 14, 2006 | 04:36 AM
jonathan_in_ky
I don't think the engine is a first generation. It is a 99. The car it is now sitting in is a 1998. I'm just trying to decide what computer I need for that engine.
Old Sep 15, 2006 | 11:51 AM
Snoopy's Avatar
Snoopy
been there done that
if it's a b16 from a 99, why would you need a clutch conversion? :eh:
