gs-r or b20 pistons
Old Dec 1, 2006 | 12:24 PM
Intege_92's Avatar
Intege_92
BAD ASS TEXAS BOY
Default gs-r or b20 pistons
I have a 92 integra ls ( db1 ) i want 2 know what pistons would be good 2 use for a all motor setup maybe some forced induction down the road. I know the gsr pistons will raise my compression and the b20 will lower it. whats better and yes i searched
Old Dec 1, 2006 | 02:44 PM
Snoopy's Avatar
Snoopy
been there done that
b20 pistons are 84mm. your stock bore is 81mm. no way to fit those in there unless you resleeve and overbore. at which point i wouldnt even use b20 pistons.
p30 or p73 pistons are ideal for NA. not so much so for boost.
Old Dec 1, 2006 | 05:32 PM
Intege_92's Avatar
Intege_92
BAD ASS TEXAS BOY
Yes i know i have to bore it . Im about 2 send my block 2 a machine shop but i havn't decided what pistons 2 use or if i want keep the stock ones . I just heard that if I use gsr pistons I have to modify the pistons and rods. Has anybody used ITR pistons on a ls bock if so ,what do I have 2 do 2 slap those babys on.
Old Dec 1, 2006 | 05:46 PM
Snoopy's Avatar
Snoopy
to use itr or any "R" piston with ls rods you'll need to shave 1mm off each side of the small end of the rod
Old Dec 1, 2006 | 05:51 PM
Intege_92's Avatar
Intege_92
BAD ASS TEXAS BOY
Well what pistons can i use without modifiying the crank or rods
Old Dec 1, 2006 | 05:53 PM
Snoopy's Avatar
Snoopy
p30's
Old Dec 1, 2006 | 06:21 PM
Intege_92's Avatar
Intege_92
BAD ASS TEXAS BOY
Wont I have 2 resleeve the block 2 put those on and what kind of boost will I be looking at if I add 403 crower cams will that be a good combo
Old Dec 1, 2006 | 06:30 PM
Snoopy's Avatar
Snoopy
you only have to resleeve and over bore if you use the b20 pistons as they are 84mm. every other b series piston is 81mm and will drop right in, provided the cylinder walls are still in good condition.
p30's will but your compression at ~11.5:1 and will work nicely with crower 403's.
Old Dec 1, 2006 | 07:05 PM
Intege_92's Avatar
Intege_92
BAD ASS TEXAS BOY
Thanks for the info ... Oh yeah im also goning 2 port and polish the head and do a 2 angle valve job and resurface the head. do you think if i go with the p30's I'll lose bottom end
Old Dec 1, 2006 | 07:07 PM
Snoopy's Avatar
Snoopy
with the stroke on an ls and those cams, i dont think you'll have to worry about losing any bottom end. and you'll want a 3 angle valve job.
