What Timing Belt
Old Dec 1, 2006 | 12:36 PM
Zedron's Avatar
Zedron
Turbo B20
Default What Timing Belt
I just put a B20B in my 94 Teg and am using teh B18B LS head on it. What timing belt do I need to use? The one for teh b18B is too small and teh CR-V one is the same part number as the B18B one so it too is small. Thanks
Old Dec 1, 2006 | 12:42 PM
ED9man's Avatar
ED9man
driver
They are a bitch to get on, what you think is too small probably isn't.
Old Dec 1, 2006 | 12:48 PM
Zedron's Avatar
Zedron
Turbo B20
Ive changed the one on my B18B before and it wasnt as hard as it is on this one. The B20 has an ITR Water Pump in it. Will that make a difference? I bought a GSR belt also because I think it is bigger.
Old Dec 1, 2006 | 04:39 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yes, the water pump will dictate what timing belt to use. The vtec water pump has a different amount of teeth on it compared to the non-vtec one, so you need to use a vtec belt with a vtec water pump and vice versa.
