I need some help with a B20Vtec Turbo Setup
Old Oct 31, 2006 | 04:25 AM
foshomofo's Avatar
foshomofo
Default I need some help with a B20Vtec Turbo Setup
Hey everyone..
i need some info on the B20vtec Turbo setup...i have an all motor GSR with 220 whp...but its gettin too slow...no tq...thats y i chose the b20...heard they have alot of tq..anyway..i just wanna know what i need to do...where to start...what to start with...yada yada yada...lookin to make 400 -450 hp :irock:
Old Oct 31, 2006 | 11:23 AM
Snoopy's Avatar
Snoopy
been there done that
take your current block and replace the pistons with low compression ones. what have you done to the head?
Old Nov 5, 2006 | 12:39 PM
foshomofo's Avatar
foshomofo
im running my gsr head i have now..p&p..have BLOX type B cams..but goin back to stockers...all S2 valvetrain..S2 IM...S2 70mm TB
Old Nov 5, 2006 | 01:26 PM
foshomofo's Avatar
foshomofo
and im not gonna use the shitty b18 block...no displacement or stroke..im re-sleeving the b20 block...and boring it to 85.5 mm. just throwin that out there
Old Nov 5, 2006 | 04:01 PM
Snoopy's Avatar
Snoopy
i would stick to a 83-84mm bore if you're going to boost it. leaves plenty of room for a rebore if necessary.
Old Nov 7, 2006 | 10:27 AM
foshomofo's Avatar
foshomofo
why?
Old Nov 7, 2006 | 11:22 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by foshomofo
why?
Because if you need to rebore the cylinder for some reason (failed ringlands, dropped valve, or other catastrophe), 85 mm won't leave much meat on the sleeves to rebore. You will probably have to resleeve in that case with a bore that large.
