vtec not cracking when its cold????
Old Oct 22, 2006 | 02:03 PM
mr22na's Avatar
mr22na
Miss It.
Default vtec not cracking when its cold????
One of my fellow employes tld me that he doesnt liek Vtec because when your engine is cold Vtec wont crack... is there any truth to that...but i sed to my self why does it matter...its not liek your goin to start your car after a winter night an right off the batt race some one...you obviously have to dirve some where to get there and by that time it should (engine) have warmed up... any ideas
Old Oct 22, 2006 | 02:07 PM
Snoopy's Avatar
Snoopy
been there done that
vtec will not engage unless certain conditions are met. engine up to operating temps, enough oil pressure, over a certain speed, over a certain throttle position, etc.
if your friend is driving hard enough to try and engage vtec when the engine is still cold tell him he's an idiot.
Old Oct 22, 2006 | 02:32 PM
mr22na's Avatar
mr22na
Miss It.
no he doesnt have a VTEC engine...he refuses to use a Vtec block...i belive he has a JDM Si crx motor...he told me hes workin on makin it rev out to 1100 rpms...i kinda ignored him on that i figured that past 6000 rpms that motor stops makin power...but i could be wrong...what do u think
Old Oct 22, 2006 | 02:34 PM
Alexs '05's Avatar
Alexs '05
Orange Murcielago > me :)
Just like Snoop said, won't engage when it's cold, etc etc
Old Oct 22, 2006 | 02:35 PM
mr22na's Avatar
mr22na
Miss It.
quick question is the only diff between vtec an i-vtec is that the oil can be changed ( in the i vtec) every 10,000-15,000 miles... my boss drives a accord and told me the dealer told him with good oil an with i vtec he could go 15000 miles befor an oil change.
Old Oct 22, 2006 | 03:45 PM
Snoopy's Avatar
Snoopy
you're friend is a moron. plain and simple.
ivtec has the variable valve timing and electronic lift control of a normal vtec, but also has vtc, which allows continously variable cam timing.
Old Oct 22, 2006 | 06:08 PM
Fuse's Avatar
Fuse
only 1100 rpms thats tight.vtec all the way why would you want to miss out on a higher lift and duration cam at higher rpms and a nice idle with good low rpm power.best of both worlds.and ya so what it doesn't work cold you don't want to push your engine when its cold.
Old Oct 22, 2006 | 07:36 PM
mr22na's Avatar
mr22na
Miss It.
11000rpm*****
Old Oct 23, 2006 | 12:08 PM
Snoopy's Avatar
Snoopy
11000rpm*****
i stand by my previous statement.
Old Oct 23, 2006 | 07:37 PM
Fuse's Avatar
Fuse
11000rpm*****
i know what you ment i was being dumb.
