- Fuel Injectors by Holley/NOS...
- Valve Job
- Swaps are illegal right?
- Uhh Oh! I kinda fukced up the timing belt job!
- A/C and engine swap?
- how to disable turbo
- vortech s/c for b18c
- bad for engine...so i was told
- what cause turbo leaking?
- what size is this turbocharger?
- a few general questions
- RSX Type-S Auto
- Putting head back together need help
- The complete b16a1 SWAP PARTS LIST NO ONE ever bothered to type up, just for YOU!
- people with LS motors...
- Need help seperating harness plugs...
- High flow or just a pipe???
- Help please
- D16 Crank pulley bolt
- NOS or Nitrous Express????
- Custom piping?
- 92 2.3 Prelude Si NON v-tec
- clean burning...diesel?
- vehicle speed sensor
- VTEC wiring into a 94 Civic DX
- type r cams good for turbo??
- crx will not run is it spark or fuel or ....?
- Missing Engine
- head bolts????
- d16a and d16zc rods and pistons
- Crower cams for b16
- General High Reving machine
- Cam Question
- Cam Question
- Cold air intake? short ram? Question!
- head gasket ????
- Broken Gauge Needles - Fixable?
- Transmission case
- poss. n00b question - exhaust gaskets
- idle vibration please help
- How long does everyone let their ride idle upon first start-up?
- how long does everyone let their car warm up at first start-up?
- code 17 in 00' SI
- New life for old Teg
- turbo vs supercharger on highway
- Oil Lines?
- scatter shield
- Vacuum Chamber
- cam shaft and gear?
- anybody know if civics, integras, and accords use the same oil filter size???
- Not a Honda Q but...
- Engine running cool
- video: fast hybrid
- b18c/revhard turbo, What else?
- turbo install $$
- intercooler w/ no bov?
- Throttle Body?
- which hb is better for swap?
- B18c into 99 civic ex
- Help engine code 6
- CX and DX?
- spark plug socket
- B18C1 swap in to 99 Civic EX
- Can someone school me on clutches and flywheels??
- Could It Be A Sensor?
- Help. Rattling noise when in gear.
- Ultimate Turbo Setup
- What if the engine blows...
- anyone have this problem....
- Titanium Retainers
- B16A2 buildup
- 90 accord lx w/h22a
- 03 Civic Ecm
- anyone who knows anything about turbos!!!
- where can I get a good price on a factory manual??
- need advice on O2 sensor and catalytic converter (replacement)
- Came to a conclusion...JRSC + nitrous
- question about boost and spray
- fuel system?
- TDC - This damned manual is making me feel like an idiot!
- B16A Swap whats needed for my app...
- nitrous
- Idle is still high
- Heating problem.
- Redline tranny fluid
- need help identifying the b16a!! asap
- Rpm Guage Not Working Right
- what swap to do on my 90 SI hatch
- b18c in a civic... now what
- Hestitation in 1st/2nd starting out...EGR?
- what is a flex pipe?
- cylinder head assembly questions
- simple brake questions
- Knock Sensor
- What exhaust....
- Car won't start? Fuel pump?
- GSR block
- B-series and D-series motors
- idle adjustment
- GSR vs B16 injector specs
- North NJ Region SCCA and ImportExpressions.com March Meet in Englishtown
- CivicSiRacer's March Meet in Englishtown
- Ls/vtec??
- b16a head on b18c1 block??
- Jrsc ?
- pleeezzz tell me somethin gi dont already know
- s80 in replace of y80?
- Engines in and I'm close to cranking it but.......
- Insane Hybrid Integ
- Crazy Hybrid Integ
- JRSC to my 96 D series
- B18c1 Vs. B18c5
- is getting rods worth the money?
- Performance enhancement opportunities with Intake Manifold and/or Timing Belt?
- AEM V2 dyno numbers
- Cam Question
- Best suspension possible for hatchback
- Cat Coverter
- B18C, what year should i get?
- SRR D16 Flywheel - Wrong Clutch Bolt Pattern?
- Cooling System Q
- b16 or b20 oil pan fit GSR motor??
- Help!!!! Engine Check Light Activated!!
- no spark, distributor?
- website on Honda's information
- BOV swap???
- oil change
- Pontiac Grand Prix GTP
- Q: for all you smart people i.e. inspyril & Mr. Fatbooty. etc.
- Off the way Q???
- CAI Intstall
- Anyone familiar with swap wiring wanna make $200+?
- JG 301 cams?
- Is 2.5" exhaust piping too big?
- starter question
- Help on engine building
- Is GReddy the only smog legal turbo?
- JRSCed TypeR hatchback!
- Bov install Q
- couple of questions
- Timing Belt Problem
- Ring & Pinion Gear ratio kit?
- turbo ?
- start up precautions after winter storage?
- is it worth to upgrade to ITR fuel injectors?
- oil change
- Next step for my b18c1??
- 95 cx hatch
- H23aVTEC Build
- ERL MF2 Additional Injector Controller
- b18c headgasket timing adjustment
- 170 and 171 codes in my 98 civic lx
- total seal rings
- n2o thingy for cooling intercooler
- rebuild or buy one???
- starter problem maybe?
- Question about a '95 vtec intake manifold?
- how much to swap
- Question about Heads
- loss in compression = loss in how much hp?
- Where to buy engines
- question about engine swap and weight
- SpiralMax?
- header
- nocking/tapping sound - 94 ls integra
- Skunk2 Stage1 tuning
- Spoon, Mugen,KS Rom chips.........anyone?
- valve seals... easy fix?
- Clearance issues
- "bouncy" wheel spinning
- Insight Swaps??
- HASport kits. ****s and giggles
- T/B change: do new belt tensioners too?
- Civic/GSR tech help needed bad!!!
- Hacking up a Turbocharger?
- B16a overheating!
- mounting type r pistons one B18A rods
- Nitrous problems!
- hondata tuning near pittsburgh
- I want 300 hp! Give me some setups
- theoretical question
- help, engin make strange noise!!
- B16A2 Civic, wont start, I need some help!!!
- 00 GSR throwing codes
- h22 into an eg civic coupe
- 98 b18c1 swap problem
- turbo install questions
- jdm d15b
- not really tech related...
- B18C1 or H22A???
- 1991 Accord Oil LEAK HELP
- I need info on ross pistons 8.5.1
- Decent price for a B18B??
- CEL code 6
- Turbo on D series civic (SOHC) and Automatic tranny
- Head stud question.
- blew my engine, b18c questions
- Need Help With Vacuum Lines
- Aem Ems
- Distributor shaft question
- EBC for under $50 ???...... It's possible look inside
- radiator problems
- differences between b16a2 and b16a1 longblocks
- Another ITR LSD question?
- 95 civic Exhaust question
- Turbo
- Heater
- What would you do?
- code 22!
- What is VTEC
- some q's i have about a swap
- Obd-i -> Obd-ii
- Help Me Please
- The scam of ebay
- b18c1 in a 92 cx. opinions on what next
- To rebuild or not to rebuild?
- Dry nitrous on 96 civic DX
- B20a5 prelude tranny will it work for Ls motor ?
- What the hell kind of pistons do I stick in this fawker?!!!
- 2-3 psi on stock h22a1?
- Tranny coolers... are they necessary??
- brownish red dust inside distributor
- girl's car is still messin up
- cam gear settings & timing changes??
- D15B7 block D15Z1 Head help please
- i need your help
- Exhaust manifold bolt broke.. how much to fix?
- BUSTED NOS Hose
- Question : Check Engine Code 1164
- difference in these heads?
- what the hell is wrong with my motor?
- Gains from P&P
- How many USDM H22a owners?
- reseting ecu
- Darton Sleeves
- torque specs and head studs sequence
- turbo overview
- any quick temporary fix for bad rings?
- Good place to research ex. internals, motor swaps
- Question about running NOS on an Si
- ZC+D16A6 Internals
- what does a "head" do?
- Quick word about WWW.HMOTORSONLINE.COM
- V-AFC h22a question
- what to do?
- Rebuild gsr or prelude?
- Water Pump Question
- fuel pump bs
- what about the prelude engine?
