turbo install $$
Old Feb 13, 2003 | 04:02 PM
hyperlite's Avatar
hyperlite
Default turbo install $$
how much does it usually run for a place to install a turbo w/intercooler. also, how much to uninstall?
cuz im just fed up with these gay cali smog laws. i'm just gonna throw a revhard kit on there, then get it uninstalled in two years. so i just wanted to know the price, thanks
ohya, its on a b18c
Old Feb 13, 2003 | 05:23 PM
drift's Avatar
drift
Flaccid Member
depending on where you go, it's usually around $600-800 for a well done job. removal should be about the same since it's the number of hours it takes to do the job that dictates the price.
Old Feb 13, 2003 | 06:00 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If you have tools, do it yourself and save some money. The only thing you may need outside help for is the downpipe, since RevHard DPs end with an open pipe and you need to add whatever flange or flex section you need to it. You can do most of the install yourself, and have a muffler shop finish off the DP to connect it to your cat/exhaust.
