vehicle speed sensor
Old Feb 16, 2003 | 06:44 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
Default vehicle speed sensor
ok here is the deal
im getting random drops on my speedo. i get the code for it too...but then i can reset the ecu and it wont come back for a long a$$ time. i dont get it. is a magnetic pickup sensor going out or what? its really pissin me off cause ive finally got all the little "bugs" worked out of alleys swap and now this thing is givin me fits. anyone know the symptoms of that sensor going bad? maybe a loose wire?? ive checked the wiring and unless its in the harness thats not the problem...its putting the engine in safe mode and flooding the crap out of it...this thing is about to piss me off
thanks for the help on the idle...i got it adjusted just right and it was running well for having long gears earlier....you could even hear the vtec enguage :chuckles: pretty impressive for a sohc
Old Feb 19, 2003 | 02:15 PM
JDM-B18C-2KHB's Avatar
JDM-B18C-2KHB
Hey im haveing the same problem, its really wierd, if i have all my accessories off then my speed will register, but if i turn on my lights or hit the brake, or turn on heaters, it drops to zero. then i get code 17, also, if your car reads under 2mph vtec wont engage, but when i reset the ecu, it goes away, and it works fine for a while, i did a swap also. ITS PISSING ME off as well, I hope we can find out what the problem is.....
Old Feb 19, 2003 | 06:59 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Code 17 is for the Vehicle Speed Sensor. You either have a defective circuit going from the VSS to the ECU, an unplugged VSS, or a busted VSS.
Old Feb 20, 2003 | 09:26 AM
silverstreakin
TRD japan ownerages
yeah...i knew what code 17 was...i was wondering more about symptoms of the sensor being bad. if you reset the ecu...itll work fine for a while then throw the code :dunno: im just gonna get alley to get a new vss for the damn thing
Old Feb 20, 2003 | 01:09 PM
JDM-B18C-2KHB
if it had t defective circuit how do we fix that?, cuz it cant be broken, since it works somtimes and sometimes it doesnt.
