High flow or just a pipe???
Old Feb 17, 2003 | 05:56 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default High flow or just a pipe???
hey guys i need a question to be answered like asap please! my cat is acting weird, it bogs like hell whenever i'm sitting in my car for about 3 mins at 800-1200 rpm..whenever i try to go its like it won't untill i push in the clutch and rev it high 4000rpm +! and i was wondering if i had a muffler shop make a "test pipe" or a cat with the bolts all lined up right but instead of the CAT CONVERTER i would just have a pipe instead, and i was wondering if that would make it better, and if so, how much louder? 1 more question.......................................... .................................................. .......................................i have a full cat back R&D thermal exhaust and i was wondering if i had the muffler shop make me an axle back pipe and buy a tunabe or 5ziggen or something to make it softer if i got that "test pipe" would it be NOT so loud? or can anyone tell me what muffler brand would NOT make my set up so loud? thanks guys!!!
Old Feb 17, 2003 | 06:10 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
What makes you think that a messed up cat is the cause of your problems?
Old Feb 17, 2003 | 06:25 PM
ZiviCase10287
RacinMasonC
Lets see, the cat converter is gutted and when i press on accelerator it has an exhaust leak, and yes i can hear it coming from the heat shield, and like i said if i let the exhaust build up from sitting in 1 spot for more than 2 mins, when i try to leave it sounds like no exhaust is getting through and it sounds like that right under my feet so that is the cat converter again.. lets see.. before when it didn't have a leak (wasn't as loud) it never never did this..... anything else you would like to know?
Old Feb 18, 2003 | 06:29 AM
v4lu3s's Avatar
v4lu3s
put a NON screwed cat in there.
and i doubt you will get an exhaust shop to put a test pipe in since that can lead to them receiving a $10,000 fine for it.
Old Feb 18, 2003 | 02:16 PM
ZiviCase10287
RacinMasonC
acutally a shop said they could make it if i took off the cat converter and let them make one from the specs of the cat converter...... and its actually $50,000!
Old Feb 24, 2003 | 03:34 PM
hlhiii's Avatar
hlhiii
i'm running the thermal r&d with a powercore race cat (basically a test pipe). the cat gave better throttle response and it made the exhaust louder, especially when vtec kicks in. i paid $150 for mine including shipping and it even came with the bung for an o2. of course i got cel 67 so i had to put in a o2sim. but the pipe is polished stainless and comes with gasket and hardware.
Old Mar 2, 2003 | 05:47 PM
tegon-gsr's Avatar
tegon-gsr
you can get a carsound cat from a place called muffler tech they also do test pipes there they will make it so its ready to bolt on and you can put it on your self it cost me 102 shipped
Old Mar 7, 2003 | 04:21 AM
xbladr's Avatar
xbladr
Where can i get an 02 sim and do u need the oxy sensor after ur cat because my dx has the cat in the header and i just got a new header and high flow cat. The header has 2 o2 bungs but i dont know if i put one in each it will shoot a code off or not. please let me know thanks.
