Bov install Q
Old Jan 31, 2003 | 05:15 AM
TaylorC01's Avatar
TaylorC01
Default Bov install Q
i need to know how to install a BOV on a 94 integra .. we think we got it hooked up right but its not makin' a "pshh" is it sposed to or is it just sposed to do that on high amounts of boost?.. the teg is runnin' about 5psi.. ?? any info??
taylor
Old Jan 31, 2003 | 06:49 AM
qtiger's Avatar
qtiger
The sound will depend on the BOV, the amount of boost run, and whether you vent to the intake tract or atmosphere.
It could be that you got a BOV with too stiff of a spring, which would mean that it wouldn't open for your boost pressures...
Old Jan 31, 2003 | 09:00 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If it's hooked up right, try adjusting the tension on the spring. Most BOVs have an adjustment bolt/nut. If it's not opening, try deacreasing the tension on the spring(read: turn the adjustment bolt outward). The BOV also needs to be hooked up to manifold pressure, I don't know if you knew that.
