what size is this turbocharger?
AiResearch automotive turbochargers is owned by Garrett. they use standard Garrett sizing nomenclature.
older turbine compressors may still be found with "AiResearch" stamped on the compressor housing.
the turbocharger you have is a T04 compressor with a .50 area to radius ratio. as for the turbine's specs, it should be stamped on the turbine housing.
