Need help seperating harness plugs...
Old Feb 17, 2003 | 10:50 PM
agent87's Avatar
agent87
Need zzzzz's
Default Need help seperating harness plugs...
I know this will sound cheesily simple but I just can't seperate the engine harness plugs and the ABS harness plugs without worrying about damaging them. I can hear a click when I press on the "levers" but i can't just slide them apart. What's the secret to doing this?
Old Feb 17, 2003 | 11:24 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
They have those little weather-seal o-rings in there to keep moisture out. Some of them are a bit stubborn. Just make sure you've engaged the locking mechanism and give em a good tug. Try to pull ont he plugs themselves, and not the wires. Or, you can try engaging the locking mechanism, then prying the plugs apart carfully with a flathead screwdriver.
Old Feb 21, 2003 | 12:40 AM
agent87's Avatar
agent87
Need zzzzz's
This is a super late reply but thanks Chris. For the sake of information, I also found out that taking the plugs off the bracket makes it a whole lot easier to pull them apart. Of course, I'm probably one of the only noobs who didn't realize this... h:
Old Feb 21, 2003 | 08:14 AM
qtiger's Avatar
qtiger
Some of the brackets actually hold the plugs together.
