how to disable turbo
Old Feb 19, 2003 | 09:57 AM
hyperlite's Avatar
hyperlite
Default how to disable turbo
ok i got this idea the other day but dont know if its possible... if i were to get a turbo, before i went in to get it smoged, is there anyway i could temporarily disable the turbo so it would pass? like can i take a part off that will disable it, so the turbo has nothing to do with smog?
Old Feb 19, 2003 | 11:30 AM
qtiger's Avatar
qtiger
Dude, they pop the hood and do a visual inspection. They will notice a turbo.
Old Feb 19, 2003 | 12:40 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I KNOW! You could use some invisible spray paint! h:
AND, just click the turbo switch to off.. that should work.
:chuckles:
I've been trying for about an hour now not to say anything... but I couldn't resist.
Old Feb 19, 2003 | 01:04 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Exactly. Unless you have a CARB exempt(read: stock GReddy) kit, you are not going to pass the visual, regardless of what your emissions numbers are.
Old Feb 19, 2003 | 02:21 PM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
It's too bad you don't live in MD - no hood poppin' out here, they could care less. You could have 5 turbos under there whirring away, but as long as you fall under emissions specs, you're A-OK.
Old Feb 19, 2003 | 04:59 PM
Zedron's Avatar
Zedron
Turbo B20
Oh yeah, Too bad you dont live in florida where they have no hood poppin or emission testing, they could care less if you had a few toxic waste barrels burning under your hood.
Old Feb 19, 2003 | 05:26 PM
hyperlite's Avatar
hyperlite
CA has the worste smog laws, but we also have the worste air
Old Feb 19, 2003 | 05:27 PM
hyperlite's Avatar
hyperlite
PHUCK THIS SMOG SH!T....anyone know what the going rate is for an illegal smog check?
Old Feb 19, 2003 | 07:38 PM
drift's Avatar
drift
Flaccid Member
w3rd :thumbup:
Old Feb 19, 2003 | 08:15 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Well it's not much of a smog check if it's illegal, now is it?
I'm curious, why do they do a visual inspection when doing a smog check? If the numbers are kosher... why does it matter?
I'm not very familar with smog testing... I don't know what or IF we have any of that here in pennsylvania. h:
