cam shaft and gear?
can anyone tell me what kind of cam shaft and cam gear that will fit on a d16y8 civic ex and also on a 89 CRX si (d16a6)? and also where can i buy them from??? also, please post ur experience with it: before and after thoughts. thanks.
Originally posted by drift
Zex. never used them, but i have heard nothing but rave reviews from owners... significant gains on stock motors, and even more gains if you're force-fed or on the bottle
Originally posted by tokyoracer
yup, that's what i've been reading about the zex cam too... i heard people say with the zex cam on their d16y8 they can pull on a Si easily.. now.. how can that be so???
they're lying. sorry, but the Zex cam will add a bit of power, but it's no going to give a 127hp car more than 33hp in a cam swap alone.
maybe a 92-95 Civic Si HB... but not a 1999-2000 Si. you'll need much more than just a cam.
if zex cam stage 2 is soo popular... then how is that compared to the AEM cam? i would think all cam gear are pretty much the same. i want to find a cam gear and cam shaft that is from the same company, since i heard it's not very good to match different cam shaft and gear together.
There is absolutely no problem running a cam from one maker and a gear from another. Think about it this way: The cam gear is meant to replace the stock one, therefore it must fit on the stock cam, and the cam is made to replace the stock one and accept the stock gear, by doing this they should without a problem be able to accept each other. I run a Zex stage 1 and a Skunk2 cam gear and it's perfect.
