JRSC to my 96 D series
Old Feb 5, 2003 | 12:10 PM
Gusto222's Avatar
Gusto222
Man WHORE
Default JRSC to my 96 D series
Okay well im about to buy a JRSC w/ 12lb pulley(used set -up) for my 1996 Civic Hb -- but i wanna know if tha 12lbs will kill my engine.. waht can i do to make tha engine last..??..
HIt me back.. thanks alot...
Old Feb 5, 2003 | 01:48 PM
MNY2BRN's Avatar
MNY2BRN
I hate you too
If its a D series non vtec, dont go 12 lbs. WAY to much if you want it too last. Stay at the 6 psi and you will bw fine. But if you want more power, save up for a swap, you may here this a lot but theres a reason, its the best you can do for your car, and it will last too.
Old Feb 5, 2003 | 07:41 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
12lbs of boost from a JRSC is putting it pretty close to its thermal efficiency limit. If you're going to do that, you'll need some very good tuning, and perhaps run some water injection, since your intake charge is going to be very hot. As for your engine, the internals should be able to handle 12lbs of boost with VERY good tuning, but as soon as you detonate, things can go awry very quickly. 12lbs of boost would probably be the maximum amount you would want to run under ideal conditions, but under real world conditions, you would probably want to run less if you want your engine to continue living. Also, if you have an automatic, the tranny isn't going to be able to cope with 12lbs of boost very well.
Old Feb 6, 2003 | 05:17 AM
j-speed racer's Avatar
j-speed racer
Default 12 lbs!!
from what i've read and from what jackson racing has researched, 12lbs of boost isnt going to be safe on d16 internals, at least not everyday driver safe.
i've got a d16y8 with the jrsc and the boost upgrade (9lbs). i've been told our motors can handle 10lbs of boost on stock internals, which i'm guessing is why jackson made the 9lb pulley and not a 12 lb. pulley. anyways my car is running well on 9lbs, i wouldnt recommend going higher.
then again i know a kid who is running like 9lbs of turbo boost and a 75 shot on stock internals in his cavelier. he doesnt care if he blows the motor, i think he's somewhat trying to (reason to upgrade), but the motor has made it through two bottles already??? very surprised its still going, but its going to eventually blow, and yours probably would too.
Old Mar 7, 2004 | 06:25 PM
Beavis77's Avatar
Beavis77
Originally Posted by j-speed racer
from what i've read and from what jackson racing has researched, 12lbs of boost isnt going to be safe on d16 internals, at least not everyday driver safe. .
Sorry, I know this thread is dated, but I have tried to find info on the internet whether it is safe to upgrade a JRSC'd D16Y8 (Civic EX) engine to the 8 psi pulley which Jackson Racing sells as the "boost upgrade kit" if you have 100% stock internals. The standard pulley is the 6 psi one that comes with the kit. Will the upgrade 8 psi pulley damage the engine ? This car is a daily commuter and I NEED it to last. The only mods I have are the JRSC, JR fuel pump, air intake, and header. Thanks for any help.
Old Mar 7, 2004 | 10:04 PM
j-speed racer
the pulley upgrade should take you up to 9 or 10 lbs of boost. i've had mine on for about 10,000 miles and the 6 lb pulley for another 30,000.
if you get the entire kit (minus fuel pump since you already have) you'll be fine. in all honesty, the boost timing retarder is the most expensive part of the kit, and i really cant even tell if it makes a difference, i usually have it on stock setting.
Old Mar 8, 2004 | 12:11 PM
Beavis77's Avatar
Beavis77
:thumbup: Thanks, man. Yeah, I know our engines are pretty strong and can handle quite a bit of boost, but I just thought I would check with people who actually have the upgraded pulley before I go ahead and get it. But your input definitely helps. Thanks!
