BUSTED NOS Hose
Ok, so I hooked up my nitrous earlier and when I had everything run, I went to test it and make sure that everything was working properly but as I turned on the bottle I heard a leak and traced it down to about midway through the stainless hose. I was curious if there is anyway that the metal could be cut and pulled back and then repair the rubber hose? I am just really not in the mood to go and waste a lot of cash on a new hose when I haven't even had the opportunity to use it.
Yep. You can cut it and use fittings, or buy a new line.
