total seal rings
Old Jan 28, 2003 | 10:35 PM
kaneda3's Avatar
kaneda3
Default total seal rings
someone was telling me that their rings allow a small amount of oil by on purpose?
is this true?
and why would they do that?
Old Jan 29, 2003 | 06:32 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
You have to have a good oil control ring in order to lubricate the cylinder walls, but that's not really the same thing as you're describing I don't think.
-Harry
AIM: NDcissive
Old Jan 29, 2003 | 08:53 AM
MNY2BRN's Avatar
MNY2BRN
I hate you too
They lubricate the cylinder walls just like stock, but their key feature is less blow by then stock. Good rings, and price isnt too bad either.
Old Jan 29, 2003 | 10:00 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I have them in my motor. Good stuff. I got them from Summit Racing for just over $100.. I think..
Old Jan 29, 2003 | 11:02 AM
kaneda3's Avatar
kaneda3
well is it common for these rings to show some smoke when boost 1st comes on?
we are talking 18 psi with fully built motor(except sleeves)
mike
Old Jan 29, 2003 | 11:06 AM
1stGenCRXer
Depends on what kind of management you're running and what color the smoke is. It's not all that uncommon for a turbo engine to spit rich smoke when boost hits, but it is pretty uncommon to burn oil unless you've burnt something internally.
-Harry
AIM: NDcissive
Old Jan 30, 2003 | 07:06 AM
rev's Avatar
rev
Most oiling and smoke problems come with the hone job. If you just use a dingleball hone instead of taking your block out and having it honed by a good shop, you aren't going to get a great finish on the walls. If any one of the cylinders looks darker than the others, then it was burnished - meaning instead of cutting and removing material like the hone is supposed to, it pushed the material over, sort of smearing the metal. A burnished cylinder will never seal right and will always end up smoking.
As for the Total Seal rings, I can tell you they were on my customer's B16 Civic SI that qualified number one in class and won the class at a recent SCCA national event. I built his head and another shop did the block which ended up smoking. Don't know if the smoking was due to the rings or the hone job as I didn't see it.
Old Jan 30, 2003 | 07:36 AM
westcoaststyle
My motor smoked BAD when I first started it up and my buddy just finished his H23 with Total Seal rings and his smoked as well. Mine no longer smokes, but I have over 1200 miles on it now. FYI
Old Jan 30, 2003 | 06:14 PM
kaneda3's Avatar
kaneda3
ok well 1st i have to admit this isnt a honda engine but since i am a member and do have a honda this is the 1st place i asked
ok now that its out of the way the engine was built by cobb tuning and it took forever so im guessing they did the job right(plus it cost me over 6 grand) and the engine was broken in properly
and i was told this was normal with total seal rings just wanted to double check thanks for all the feedback
mike
Old Feb 1, 2003 | 12:36 PM
kaneda3's Avatar
kaneda3
so what now no one wants to talk to me??
