1991 Accord Oil LEAK HELP
Old Jan 21, 2003 | 04:01 PM
agugliel's Avatar
agugliel
Default 1991 Accord Oil LEAK HELP
can someone give me the heads up on changing the seal on the oil filter housing seal? Mine is leaking like mad>
Old Jan 21, 2003 | 05:50 PM
drift's Avatar
drift
Flaccid Member
drain oil
unscrew filter
use a wrench (i cant remember if it's 20mm or 22mm... somewhere around there) to remove the adapter that you screw the filter onto.
pull off filter adapter
remove seal, which should either be stuck to block or the filter adapter.
replace seal, reassemble in reverse order, add oil.
