What if the engine blows...
Old Feb 11, 2003 | 07:48 PM
hyperlite's Avatar
hyperlite
Default What if the engine blows...
ok say i use a 200 shot on my gsr engine and blow it up. when people use the term "blow it up" what do they actually mean? does it mean to damage the pistons? ...and if these thing(s) do get damaged, how much does it cost to replace?
Old Feb 11, 2003 | 07:59 PM
qtiger's Avatar
qtiger
Hah. With a blow like that, you aren't just talking damaged pistons. You could shatter pistons, bend or break rods, send pieces of rod or piston through the side of your block, oilpan, or transmission.
Old Feb 12, 2003 | 01:38 AM
Dave C's Avatar
Dave C
I have to vote this the stupidest question ever asked on HAN.
Old Feb 12, 2003 | 07:29 AM
preylude99's Avatar
preylude99
lol , hes right, with a "blow up" like that you are looking more at a replace of the whole motor rather than repair.... thats why people who have cars like a civic dx with relatively cheap motors run NOS on them stock because if they blow it up the replacement for those motors is so abundant and cheap that its not even worth it to build the motor up and have it blow someday anyways..
Old Feb 12, 2003 | 10:41 PM
Slow-N-Low's Avatar
Slow-N-Low
What's that smell?
I don't think it's stupid at all. If you've never seen a motor actually come apart, it's hard to imagine how much damage can be done.
To answer the question, when you think "blow it up", think about parts that were once on the inside ending up on the outside. When this happens, the flying parts aren't terribly particular about what path they take. More often than not, they go right through the block, rendering it unsuitable for future use. Think big $$$.
You can do severe damage to a motor without actually blowing it up. Shattered pistons and bent rods can leave the motor looking pretty good to the naked eye, but still unusable. Melted pistons and bent valves also happen if you're not careful.
Old Feb 13, 2003 | 07:38 AM
v4lu3s's Avatar
v4lu3s
100 shot, plus overrevving (lean...boom)
this was a miata engine, iron block.
Old Feb 13, 2003 | 08:59 AM
dubcac's Avatar
dubcac
I
This is why window switches are a good idea on nitrous. If you overrev, your motor will live to see another day.
:thumbup:
Old Feb 13, 2003 | 09:02 AM
v4lu3s's Avatar
v4lu3s
the scary thing...he did that for 8 months!!!
it finally belw, 2 pistons were like that....then he rebuilt with forged stuff and overbored to 2 liters....i wish my honda would hold up to that kind of abuse!
Old Feb 13, 2003 | 10:39 AM
skratchnsnift's Avatar
skratchnsnift
boom
note to self: dont blow up engine
Old Feb 13, 2003 | 02:20 PM
Slow-N-Low's Avatar
Slow-N-Low
What's that smell?
I'd use a rev limiter no matter what. You don't need nitrous to turn an engine into junk. Force increases as the square of velocity, so RPM alone can pull a motor apart. A couple hundred RPM at redline puts more stress on parts more than a couple thousand RPM down low.
