is it worth to upgrade to ITR fuel injectors?
Depends on your setup. If you're running lean, you may want to think about it, but you'll end up too rich if you just want more fuel.
The fuel system is special in that it all needs to work together. You can get an intake and it will help your hp gains, but if you just add more fuel, you're going to make things worse (depending on how much you add).
All B series are 240cc's
All D series are 240-cc's
92-96 H22a1's are 270cc's
97-01 H22a4's are 290cc's
H22a1 injectors are a bolt on affair for all b16a2 fuel rails, all you need to do is lengthen the 3rd and 4th plugs
Cool huh,so no it wouldn't do you any good.
Isn't that what RC can make them?Are you maybe talking about the H23A or A1 or the H22A1 from 94-96,or I am I getting owned?Also the is a 50cc jump between the B and D 1.6 to the 2.2l H series I don't see the need for such a big jump for .1 liters.
And another thing rc doesn't have 345cc injectors
Saturated:
160cc / min
$76.50
185 cc / min
$78.85
200 cc / min
$79.90
210 cc / min
$79.90
225 cc / min
$81.50
240 cc / min
81.50
270 cc / min
$83.75
310 cc / min
$85.65
370 cc / min
$88.30
440 cc / min
$89.75
500 cc / min
$135.00
600 - 800 cc + / min
$150.00
Peak hold:
155 cc / min
$78.90
185 cc / min
$78.90
195 cc / min
$79.85
210 cc / min
$78.90
220 cc / min
$79.85
250 cc / min
$78.90
270 cc / min
$82.50
320 cc / min
$86.45
370 cc / min
$84.50
400 cc / min
$84.50
450 cc / min
$85.36
500 cc / min
$89.42
550 cc / min
$95.42
650 - 800 cc / min
$185.00
800 - 1200 cc / min
$215.00
1400 - 1600 cc / min
$237.50
But this is just their website,it could be wrong.Meaning they might not be listed don't get in a twist.
Saturated:
160cc / min
$76.50
185 cc / min
$78.85
200 cc / min
$79.90
210 cc / min
$79.90
225 cc / min
$81.50
240 cc / min
81.50
270 cc / min
$83.75
310 cc / min
$85.65
370 cc / min
$88.30
440 cc / min
$89.75
500 cc / min
$135.00
$150.00
Peak hold:
155 cc / min
$78.90
185 cc / min
$78.90
195 cc / min
$79.85
210 cc / min
$78.90
220 cc / min
$79.85
250 cc / min
$78.90
270 cc / min
$82.50
320 cc / min
$86.45
370 cc / min
$84.50
400 cc / min
$84.50
450 cc / min
$85.36
500 cc / min
$89.42
550 cc / min
$95.42
650 - 800 cc / min
$185.00
800 - 1200 cc / min
$215.00
$237.50
i think the h23a1 is the 270cc, i know h22a1 is either 320cc when measured at 85% duty cycle or 345cc when at 100% duty cycle.
the vtec cams on the h22a are a lot of lift....i know the fuel maps for the p72 ecu cant really handle the large injectors and cam lobes til high rpm...
