is getting rods worth the money?
Old Feb 5, 2003 | 06:24 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Default is getting rods worth the money?
I am thinking about getting rods for my motor. I wil have pretty high comp. pistons and I have upgraded almost everything else. I am just going n/a. no nitrous or anything. Do you think it would be worth it?
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Feb 5, 2003 | 06:56 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
This is the B16A with the LS crank right? I would get some "bargain" forged rods like Eagle or Crower Econobillet just to be on the safe side. You can usually pick up a set for less than $400.
Old Feb 5, 2003 | 07:28 AM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
sounds like a winner to me....high compression owns me!
Old Feb 5, 2003 | 08:25 AM
Import-Tooner
skoooooie!
Your exactly right. and eagle is what I was looking at. 300 shipped to be exact.
SKOOIE!!!
Old Feb 5, 2003 | 08:27 AM
Import-Tooner
skoooooie!
actually, b18c with b16a head and ls crank and rods.
SKOOIE!!!
Old Feb 5, 2003 | 09:55 PM
ryewdedyet's Avatar
ryewdedyet
You might want to also do some grinding (radius curves) at the bottom of each cylinder to ensure the rods will not touch the bottom of the cylinders during high revs. Just a suggestion.
Old Feb 6, 2003 | 11:03 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I've never heard of anyone having to notch the block to fit aftermarket rods in a B series. It's a pretty common practice for D series blocks though. You should doublecheck your clearances, of course.
