Is 2.5" exhaust piping too big?
Old Feb 1, 2003 | 07:29 AM
Import Driver's Avatar
Import Driver
Default Is 2.5" exhaust piping too big?
I'm thinking about an h22 swap. But I need to know is 2.5 inch mandrel bent piping too big for a NA h22a motor (with high-flow cat & muffler)?
thanks
Old Feb 1, 2003 | 07:42 AM
ISP James's Avatar
ISP James
DAMIMRED
i dont think it's too big.... i have 2.25 on my d16 civic and didnt lose any power that was noticable.... so im sure a h22 can push it alright...
Old Feb 1, 2003 | 03:50 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
you'll be fine with 2.5. if you go 2.25 you'll have some more low end grunt. that's all.
if you are doing a build up the 2.5 will def. be used then.
Project EVA - The Track Package
Project EVA
Old Feb 1, 2003 | 04:46 PM
Import Driver
hey thanks guys thats nice to know. Yeah, I would sacrifice low end for top end so thats cool. Plus (like you said bumnah) if I ever do end up building it up NA or turbo then I wouldnt have to upgrade exhaust again. I think I will go Stainless steal 2.5". mkteller8@aol.com sells mandrel bent piping and has good prices.
thanks again
Old Feb 1, 2003 | 11:02 PM
drift's Avatar
drift
Flaccid Member
no current exhaust manufacturer builds a 2.5" diameter exhaust for the H22A.
i think it has something to do with proper research and development to provide optimum power.
Old Feb 2, 2003 | 04:32 PM
qtiger's Avatar
qtiger
It has more to do with the fact that most exhaust manufacturers are looking to build bolt on systems, which are usually built the same size as the exhaust manifold collector.
2.5 is a good size.
Old Feb 3, 2003 | 05:06 AM
Import Driver
Originally posted by qtiger
2.5 is a good size.
good, thanks!
Old Feb 3, 2003 | 03:25 PM
drift's Avatar
drift
Flaccid Member
2.5 is a good size.
no one makes a 2.5" collector on their header in the aftermarket except the Kamikaze system (but their short primary system is anti-productive). plus, it would require a catalytic converter changeout.
a stepped system, i.e. 2.25" collector and catalytic converter combined with a 2.5" exhaust, will cause exhaust flow turbulence.
like i said, do all the research first as the aftermarket already has.
Old Feb 3, 2003 | 05:07 PM
qtiger's Avatar
qtiger
The common aftermarket has produced bolt on parts, not horsepower. Good dyno gains have been seen moving to 2.5" exhaust systems on B series engines. I can't see how an engine with a larger displacement and high valve lifts can possibly benefit from a smaller exhaust system.
AN-R produces a header with 2" primaries and a 2.5" collector. Hytech, SMSP, and Burns Stainless are other good choices.
Old Feb 4, 2003 | 07:38 PM
CARLITO's Avatar
CARLITO
QUICKERSILV3R
I wouldnt go any bigger than 2.5..If no manufactures make a 2.5inch exhaust for the H22 then go to a local muffler shop and I'm sure they can hook you up with something!
