- 91 Acura Legend Idle problem
- crx running lean???
- How good is a SIR B16 intake manifold
- D16Y8 Starting problems (lean)
- d16y8 camshafts
- zex dry nitrous setup question
- 92 civic vx driveability problem
- hybrid spoiler
- obd0 to obd1 which one will work????
- B18c Advice
- MSD blaster 2 coil installation help!!
- P06 vs.P75
- turbo or supercharger?
- del sol with GSR need some help
- i need V-TEC swap advice!!!!!!
- I have this exhaust outlet, is there a gasket? w/pic
- Sticky Tach
- Valve Adjustment on a 93 Acura Integra 1.8
- Which header? [For B16A into DC Integra]
- BRE Users...
- Adjustable cam gears
- GSR swap [OBD-1 B18C1 into DA Integra]
- 92 hatch with 97 gsr ... VTEC wiring HELP.... please check over
- can someone help me tune my apexi safc1
- is this tune shop tryin to rip me off??
- Harness
- '93 Prelude throttle/idle problem
- H22 Head Bolt On???
- question about engine
- Block guard/ sleeve saver
- Raising compression reving 10!?
- Making D17A2 super engine!!!
- GSR tranny stuck in gear
- Lookin for 95 Civic Hatchback
- 2002 Accord EX Check Engine Light Problem
- help what to do cylinder misfire 1, 2, 3, & 4
- fix tranny? or not?
- Check engine light HELPPPPP!!!
- Mini-me reliability
- Can anyone help me??
- 12 sec street car.
- 10:1 fmu with 7lb of boost on an integra ls
- b20 into 1994 teg...pix to come
- jdm and usdm wiring harness
- Same mount????
- failed smogg
- Flywheels
- 92 civic si....
- turbo kit install
- 96' integra swap?
- B18C5 swap into 95SE
- How can I advance my timming on my 94 accord
- Which Engine
- K20 EK Hatch Build 100+ pics!!
- b18c1 ticking engine
- supercharger-centrifugal or eaten?
- JDM sir2 short block
- What is needed for LS/VTEC?
- b18b rear mounting bracket????? HELP
- Help on replacing Power steering Belt for B16a2
- tuning options for obd-2
- Headers
- LS/Vtec in a '95 Civic
- engine talk
- Ticking Sound - Need Help
- Injectors
- Wiring Questions Eg With B18c
- b18a build
- SUPERCHARGER!! Help me pick one, etc
- B18 Swap
- Hydrolocking
- four cam four cyl?!
- Omni Test Pipe Weld???
- bad idle (iac)-PLEASE HELP!!
- Intake Questions
- 2000 gsr jdm b18c into 98 Civic HX (non-vtec) wiring?
- Only experts OBD0 to 1 conversion HELP
- civic si/type-r swap
- PLEASE Help Those Who Have Tucked + Relocated Wiring!!! 93 LS
- VTEC wiring: B18C in 97 LS gone VTEC
- GSR bare Block Need help asap
- Brackets for Civic Fluidyne in GSR?
- Car starts,cuts off then starts under throttle but smokes help
- Full timing belt install help
- Throttle Body help
- replacing head gasket!!!! help please!!!
- Turn b18a1 into b18c1
- How to check oil seals on a turbo
- Boring the Intake Manifold
- Skunk2 IM coolant pipe 3/8 Help on plugging it
- tps
- 87 Civic stall and then wont start
- Honda Civic Ex With Honda Civic Cx Motor
- NGK Iridium IX or Denso Iridium Spark Plugs?
- UKDM EP3 Type-r Question
- B-20 Q's
- Timing belt loose
- SRS Light help
- precision sc61 too big?
- Distributor Help
- driver side cv joint
- can b18c1 w/ 12.5:1 comp. still be a daily driver
- Hondata?
- Please Help!!! Vtec Bolt On?
- b18XX block + b16 internals = how much displacement?
- question about vtec head swap
- AEM or Hondata (EMS)high boost H22
- 94 Civic Cx Engine Honda To Ex Manuel
- B18b into 93 EG Help
- Which Intake manifold?
- HAs A MIND OF ITS OWN
- Hiflo FUEL Pump... worth it?
- clutch tranny problem
- Should I trade??
- I need some help? por favor
- Building!!!
- engine management for H22a turbo
- H22A swap into 91 accord..fuel problem
- What pistons to run
- GSR oil pump & water pump
- differences in hp w/ CTR & ITR pistons
- oil jets in b18a1
- Cams/B16a2
- My civic
- need help bad???????
- identifying intermediate/cv joints
- Nice page on fuel injection control
- fuel pressure regulator question
- Motor oil recommendations for 2000 Integra GSR
- check engine light
- Skunk2 IM install on a 01 GSR NEEEEEEDDD HELP
- JDM b16 manifold
- obd-0 to obd-1 in crx hf...
- All Integra Pros... I need some help.
- Help with info on ZC motor
- which cv boot do I need??
- trace oil in my distributor?
- Opps
- 97 honda accord
- spark plug info??
- 96 Ls Integra Error Code 70
- vtec vaIVE NOISE??
- idle problems
- K&N filter ?s
- need help!! " a starter "
- Compression test.
- V-AFC2 settings????
- nippon racing ITR pistons
- JDM h22a into 92 prelude question
- VTEC Cams.
- Need info for D17A2
- Help w/ head work
- Hood problem
- Hood problem
- Turbo Accord revs up to 5000 rpms on its own, back down to 500 rpms, then repeats
- Omni Test Pipe 3pc?
- To Sleeve or not to sleeve
- help with my b16a2
- Help - Transmission Troubles!!!
- GSR Knock sensor - is this it??
- GSR or B16 intake cam
- i need help. ive got a 98 ls engine swapped into a 96 gsr body.
- Got my code, but what does it mean?
- Building B16 head! What do I need exactly?
- How can I keep Integra GSR reliable?
- Cold start issue
- not getting spark
- Stage 1 cams.
- Any suggestions?
- ls turbo build up need info
- ecu question
- f22b1 sohc
- f22 nto a 90 crx????
- yet another question about uberdata
- timing the dizzy question
- B16a2-build Or Not
- HAsport mounts good or bad
- LS Engine Stall - need help
- turbo whines and problems
- Motor For Sale
- Radiator Fan not coming on when hot. Any elect. gurus?
- b18 head?
- Tranny question?
- b16 block gsr head? any good?
- Radio
- civic beat 350z
- Horsepower Gains
- Top speed limiter
- Teg GS-R Engine Swap
- I need some help on my vtec engine
- Engine swap question??? Help
- h22a proyect needs help
- Price check on Honda oil filters, Oil drain plug washers, Honda Filter Wrench
- b18c weird knock
- custom turbo setup
- Turbo Questions
- Need some advice
- Ecu/Elec management Q's
- B2 - A6 head comparison
- digital boost controller or manual boost controller
- RSX DC5 shoft shifter install?
- Installed Greddy turbo kit: engine management question...
- CRX/Integra susp conversion
- b16 into 92 hatch, trans problems.
- Chattering clutch
- Weird Engine Cut Off/on Problem
- Cylinders misfiring on my CRV?
- is ls/vtec turbo stable?
- turbo ls/vtec???
- Fuse Diagram Under Dash
- Lightened flywheel
- P & P
- help
- I have a vibration in my steering wheel.
- 90 integra won't start??????????????????HELP!!!
- EGR symptoms...
- tranny issues
- headers qusetion
- Peak and Hold injectors?
- interchangable Rotor ?
- 16" or 17"s on my 98 integra.
- intake prob
- can it be done?
- which is better
- What catback? 92-96 Prelude Si
- EMs vs. performance chip vs. hondata
- Ecu
- Main fuel relay
- Aem programable computer.
- power ratings
- Please help! conversion harness
- check engine light 999 accord vtec
- what is the best intake mainfold.
- 1994 Honda Accord engin noise
- Need Some Serious Clutch Help
- Main Fuel Pump Relay Problem - Symptoms & Cause
- gsr motor
- Type R Swap Tranny Problem
- Overheating / Gasket Problems
- Calling all Honda experts - DTC help please!
- stuck with D15 motor
- Question about Vtec J35
- Halfcut and welded?
- Tranny Question
- Turbo Chargers
- new to tuning...be gentle. d16 to d15 swap
- LS crank in GSR block
- h22 engine question
- info
