What is needed for LS/VTEC?
Old Mar 10, 2006 | 11:38 AM
JWG87's Avatar
JWG87
Default What is needed for LS/VTEC?
Hi everyone
I have a 95 integra LS Stock b18b engine.
I want to a mini me swap to lsvtec.
I'm not a honda expert, so dont tear me apart, but i do know my way around...
my question is what do i need. I've heard i need a b16 head. what different heads will mount to my stock b18b. and what ecu would i have to swap in. what options do i have before i start my search for parts
thanks for your help in advance.
Old Mar 10, 2006 | 01:44 PM
95LSv's Avatar
95LSv
Banded
You will need a OBD 1 ecu, since your car is a 95. 96 and up came with obd 2. You can still use OBD2, but you have to get a conversion thing (not sure what its called), so its easier to use OBD1. As for the Head you can use i think any vtec head, B18c head, b16 head, and b17 head. With a b16 head, your OEM LS headers will bolt right up and maybe the manifold too. HOWEVER, if u want it done right, then go get some gsr or type r pistons and rods and maybe a crank too. You might want to change the OIL pump and water pump too. ALSO you need to take the block to a machine shop, have them hone it, resurface the head, tap the head for oil line and thread a hole for a KNOCK SENSOR.
Old Mar 10, 2006 | 04:15 PM
JWG87's Avatar
JWG87
actually much more complicated than i thought but im going to keep reasearching. thanks for the post
any other input guys?
recomendations?
Old Mar 10, 2006 | 10:10 PM
b16ahybrid's Avatar
b16ahybrid
recomendations?
It's actually very simple...keep your stock rods/pistons and keep the revs below 8k, if you want to run it like a vtec motor then upgrade the rod bolts, they tend to stretch under high rpm load....
Old Mar 11, 2006 | 05:11 AM
JWG87's Avatar
JWG87
"You might want to change the OIL pump and water pump too. ALSO you need to take the block to a machine shop, have them hone it, resurface the head, tap the head for oil line and thread a hole for a KNOCK SENSOR."
what is this and what is the purpose of doing so???????
Old Mar 11, 2006 | 05:27 PM
95LSv's Avatar
95LSv
Banded
You don't really have to change the pumps. But a GSR oil and water pump is better than ls. Get type r if u got the money. Resurfacing the head is necessary to ensure that everything is sealed good. Honing pretty much makes the engine like new. it cleans the block on the inside... Hope that helps
Old Mar 11, 2006 | 09:49 PM
JWG87's Avatar
JWG87
yeah it helps alot. so how much does this stuff run, the honing and stuff?
Old Mar 11, 2006 | 11:48 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
GSR and Type R oil pumps are the same exact thing.
Honing doesn't clean anything. It creates a rough surface on the cylinder walls so that new rings will seal correctly.
Old Mar 14, 2006 | 06:16 PM
JWG87's Avatar
JWG87
Hey guys i also heard a stock the ls block with b16 head will have much more significant torque that the stock ls tranny will not really be a good match for this?
Is it true?- if it is, what tranny would you suggest?/ what trannys would bolt to the b18b block?
Old Mar 14, 2006 | 06:43 PM
Provocateur
On permanent hiatus
Any B-series hydraulic tranny will fit the B18B1 without any problems. A B16 tranny is one of the best early upgrades to an ls vtec setup because of its short ratios that speed up acceleration.
