92 hatch with 97 gsr ... VTEC wiring HELP.... please check over
Old Mar 20, 2006 | 04:40 PM
KangolBrand's Avatar
KangolBrand
Default 92 hatch with 97 gsr ... VTEC wiring HELP.... please check over
I have a 92 hatch with a gsr swap im using a p28 just to see if im wireing up vtec correctly or not. Which is not becuase I do not hear it engaugeing or feeling it. I aready check if pin d4 is giving power out for the solenoid which it is not. So if anyone can lead me to a site or a answer as to why vtec is not engaugeing. But when I power d4 with a switch I can hear the solenoid open
I areadly wired
VTEC solenoid yellow/green a 4
VTEC oil pressure sensor blue D6
VTEC ground black chassis ground
knock sensor red/blue D3
Secondary intake solenoid (IAB) pink/blue a17
What I didnt wire yet but well when I fine where its located
1.Evap purge power yellow/black 12V power
2.Evap purge solenoid red A20
Would not having hook up cause vtec to not engauge?
Please help if you can, thanks in advance.
Old Mar 20, 2006 | 06:12 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
>move to hybrid...is the p28 chipped?
Old Mar 20, 2006 | 09:19 PM
KangolBrand
no its not chip but shouldnt it work just to test ? I could be wrong. Thanks for the help
Old Mar 20, 2006 | 09:20 PM
KangolBrand
should i put the same posting in hybrid? or a mod can do it?
Old Mar 21, 2006 | 06:24 AM
sherwood's Avatar
sherwood
I missed Sean
there is no secondary intake output on a p28.... i know that for sure.
Old Mar 21, 2006 | 02:23 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
No need to post a duplicate.
Moved to Hybrid Forum.
