Which header? [For B16A into DC Integra]
Old Mar 21, 2006 | 10:33 PM
95LSv's Avatar
95LSv
Banded
Default Which header? [For B16A into DC Integra]
I am about to swap a jdm b16a into my gsr (which came w/ ls motor), and my question is, which header do i need to make it all work? A b16 or b18?
Old Mar 22, 2006 | 12:47 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
b16.... but i think they may have the same bolt pattern ... someone else confirm?
Old Mar 22, 2006 | 05:02 AM
EX plicit's Avatar
EX plicit
OH SNAP!
Both will bolt up the same.
Old Mar 22, 2006 | 02:22 PM
95LSv's Avatar
95LSv
Banded
Yes they will bold up, but will the bottom meet up with the cat in the right place?
Old Mar 22, 2006 | 09:29 PM
95LSv's Avatar
95LSv
Banded
Anyone know for sure which will bolt up with the cat at the bottom w/o having to customize anything?
Old Mar 22, 2006 | 09:32 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you are just swapping the head, the stock header you were using will bolt up with no modifications.
If you are swapping the entire engine, don't.
Old Mar 22, 2006 | 10:32 PM
95LSv's Avatar
95LSv
Banded
The whole thing... The block is SIR2 w/ and the head is 99 si... Now what kind do i need?
Old Mar 23, 2006 | 08:08 PM
95LSv's Avatar
95LSv
Banded
need help asap... trying to get a header for a good price, but i just don't know which will fit...
Old Mar 23, 2006 | 08:41 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Seriously, given the variance in collector lengths between models of the DC Integra, I would expect that you will need some degree of custom fabrication to mate up to the catalytic converter. Besides, I assume you're going to want a custom cat-back exhaust to accompany the new motor.
Since the motor you are retrofitting is dimensionally similar to a USDM B16A2, a 99-00 Civic Si header should clear the oilpan.
And lastly, please do not thread bump. We have a search engine feature that is just as fast and may even answer your question.
Old Mar 23, 2006 | 10:04 PM
95LSv's Avatar
95LSv
Banded
Well i tried searching this, but i could not find this same problem... and I don't see why thread bumping is a no no here... is there a rule or something? (im sort of new)
