GSR bare Block Need help asap
This guy is selling a 95 GSR bare block and a crank and rods, all with around 9x,xxx miles on them. Hes asking $200. Is this a good price, because i would like a gsr block...???
That is not a standard size. The standard size is 81mm, so that is a 2.0L if you use the GSR crank. Unless it is sleeved, I would stay away from it, though. Stock sleeves bored that much will crack.
Originally Posted by 95LSv
Thanx Schmoo, you've been very helpful
. Oh and can you tell me if ACL rod/ main bearings are good? This guy is selling a whole set main, rod and including thrustwashers for $75.
. Oh and can you tell me if ACL rod/ main bearings are good? This guy is selling a whole set main, rod and including thrustwashers for $75.Also make sure you plastiguage the clearances.
Yea ive just read about that today on Cspeedracing. But what do I do if there isn't enough clearance??
Crap, thats gonna suck since i just bought the ACL's. Can i just shave the bearing?
And you know when you do a valve adjustment, does the head need to be on the block, because myne isn't and it seems it would be a whole lot easier to do it now before i put the LS-vtec together.
Yes, you can do a valve adjustment with the head not on the car. Just make sure the cams are bolted in securely and you know which cylinder you are adjusting.
