question about engine
Old Mar 17, 2006 | 10:23 PM
AILS91's Avatar
AILS91
Default question about engine
OKay I tried looking for it but I couldn't find it or didn't know what to put for the search engine. If I'm going to put a b16a head on a 97gsr block do I just build the bottom half gsr and put gsr cams in the head?
Old Mar 17, 2006 | 11:03 PM
95LSv's Avatar
95LSv
Banded
Well what are you trying to achieve? Yea you can build the bottom, put some high compression pistons and whatever you want... but why would you put gsr cams? I head many people say that the b16 cams have better flow... Now if you want to get aftermarket stage cams go ahead, but otherwise i would keep the b16 cams...
Old Mar 18, 2006 | 12:03 AM
95LSv's Avatar
95LSv
Banded
Dammit i meant to say heard...again... Im not retarded
Old Mar 18, 2006 | 06:54 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
What are your goals?
Old Mar 18, 2006 | 10:45 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
B16 cams were junk. Any other B series vtec cam is better. The GSR head is also better than the B16 head, so unless you have to change the head, don't.
Old Mar 18, 2006 | 11:32 AM
95LSv's Avatar
95LSv
Banded
What... dammit i thought b16 head was better... So then should I put gsr cams into my b16 head??
Old Mar 18, 2006 | 01:50 PM
Provocateur
On permanent hiatus
Yes, you should. And if you are looking for a pair...I have a set for sale from my GSR.
Old Mar 18, 2006 | 03:41 PM
AILS91's Avatar
AILS91
I was hoping to get atleast around 190hp from the engine, only reason I have a b16 is that I only have tthe bottom end of a gsr, block/tranny and dont have a head for it, so I got a b16 from a friend. I plan on upgrading the head later when I have more money but right now I just want to put this engine together with some decent power because my b18a has alot of miles on it(stupid ass dealership lied about how many miles were on the car said it only have 96k when I bought it a year ago, checked it out on line about 7 months later and found out in 01 it had 104k on it. I cant even do anything about it which really pisses me off), I'm gonna put forged pistons and rods in the block because I plan on putting a turbo on it later on. Everything in the head is gonna be stock, unless I should put gsr cams in the head then I'll do that is the gsr will work better then the b16's.
Old Mar 18, 2006 | 03:49 PM
95LSv's Avatar
95LSv
Banded
What is the number on the gsr cams? Because my si ones say pr3, so im just wondering what gsr's say
Old Mar 18, 2006 | 05:28 PM
Provocateur
On permanent hiatus
The cams themselves don't have any numbering. The cam gears all say PR3.
