What pistons to run
Old Feb 25, 2006 | 10:30 PM
twin3037's Avatar
twin3037
Default What pistons to run
looking for some good priced high compression pistons for a ls/vtec setup i've heard jdm type r's are good but will the civic type r's give to high of a compression with a gs-r head? i am aiming for 11.5:1 - 12:1 compresion ratio
Old Feb 26, 2006 | 12:21 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The CTR pistons would put the compression ratio at a very unfriendly pump gas 12.6:1. The USDM or JDM Type R pistons will put your compression rate at 11.3:1 and 11.9:1 respectively.
Old Feb 26, 2006 | 07:50 AM
twin3037's Avatar
twin3037
is this already accounting for the + . 2 compresion fo the ga-r head?
Old Feb 26, 2006 | 08:27 PM
Provocateur
On permanent hiatus
Yes, it is factoring in that you are using a B18A/B block and a GSR head.
Old Feb 27, 2006 | 08:58 AM
twin3037's Avatar
twin3037
thank your much
Old Feb 27, 2006 | 11:41 AM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
p30
