Turn b18a1 into b18c1
Old Mar 3, 2006 | 04:06 PM
gjown's Avatar
gjown
Default Turn b18a1 into b18c1
Here's my plans. I've got a b18a1 block sitting in my garage waiting for me to pour money into. My hopes are to try to get it as close as a b18c1 as possible. Reason I'm thinking this way is, my Haynes book says the difference between the base model engines(b18a1,b18b1) & (b18c1) is in the heads. I know LS motors don't have oil jets & crank girdles. But I want the long lasting reliability on GSR motor. Here's the plan: B18a1 block,GSR crank, GSR eagle connecting rods, GSR crank girdle & oil jets, ITR pistons, Gsr head P&P, Ferrea valves, Manley valve springs, crane cams, skunk2 intake manifold, eldebrock throttle body & good tuning. I know throwing the GSR crank and rods will make it have a smaller displacement. I just want good power and relialibity for my civic eg. Plus I want to be in the low 13's in a quarter of a mile. I'm up for opinions.
Old Mar 4, 2006 | 12:06 PM
b16ahybrid's Avatar
b16ahybrid
It's probably cheaper to sell the b18b block and buy a b18c block to start with....if you plan to swap cranks, machine in the oil passages for the squirters etc
Old Mar 4, 2006 | 12:47 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Use forged pistons instead of the ITR ones and you won't even need the oil jets.
