LS crank in GSR block
Old Jan 25, 2006 | 03:00 PM
EQMD EF8's Avatar
EQMD EF8
Default LS crank in GSR block
I've done a search here, g2ic.com, and h/t and can't find a definite answer to my question.
Will I loose my oil squiters?
I have a LS block that I'm going to take apart in the next few days when I get some time and try the crank, but I was wondering if anyone else has experience with this.
Old Jan 25, 2006 | 07:46 PM
b16ahybrid's Avatar
b16ahybrid
I can not say 100% for sure but i'm 90% sure that your will have to bend them or remove them. When I installed my eagle rods I had to bend them in order for the rods to clear them....that was using a gsr block w/gsr crank....the ls is going to swing further and probably hit them..
I know Golden eagle make the oil squirter caps for stroked motors, although yours isn't going from 1.8 to 2ltr like the stroker kits....
Caps are only $12....worst case scenero you have to buy a set...Are you running stock rods and pistons?
