Compression test.
Old Feb 20, 2006 | 04:28 AM
psx_pat's Avatar
psx_pat
Default Compression test.
I did compression test on my B16A head with B20B block (milled 0.75mm). But I think something wrong with my engine. I got only 142 psi on all four cylinder. Is this normal or not? Bent valves? Thanks.
Old Feb 22, 2006 | 04:29 PM
AcuraFanatic's Avatar
AcuraFanatic
Whats your compression ratio?
Old Feb 23, 2006 | 06:28 AM
psx_pat's Avatar
psx_pat
Well,according to the software I'm using from C-speed, at least should be around 9.5 : 1 compression ratio.
