Headers
Old Mar 8, 2006 | 10:49 PM
95LSv's Avatar
95LSv
Banded
Default Headers
What kind of headers would fit my setup? I am doing a ls vtec, using a 99 si head with a ls block or possible a GSR block. What kind of headers would fit? SI, or LS or what? THanx
Old Mar 9, 2006 | 04:46 AM
shivers's Avatar
shivers
Moderator Alumni
You'll want a header made for a 1.8L b series engine. Look to models for GSR or ITR. Headers made for a 1.6 will be too short.
2005 s2000
Old Mar 9, 2006 | 07:47 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You'll still probably have to get a testpipe made to fill the gap between the header collector and the rest of your exhaust. I tried B16A, B18B, B18C headers and none of them met up with the rest of the exhaust properly. B16A wouldn't even bolt up because of the height difference in the block, as Tony mentioned.
Old Mar 9, 2006 | 01:45 PM
95LSv's Avatar
95LSv
Banded
Well i have found that my LS headers bolt up to the SI head, and if i use the ls block they will fit, but with the GSR block im not sure... Can anyone tell me for sure??
Old Mar 9, 2006 | 02:09 PM
westcoaststyle
Singular -> Header
GSR and LS block are the same height. It will work.
Old Mar 9, 2006 | 02:20 PM
95LSv's Avatar
95LSv
Banded
Oh, alright then. Thanx
Old Mar 9, 2006 | 03:13 PM
Driverman5777's Avatar
Driverman5777
So if i did an lsvtec w/ a B16a2 head on my B18b block. I'd have to get a new header.
Old Mar 9, 2006 | 06:26 PM
qtiger's Avatar
qtiger
Thread cleaned and reopened. No more petty bickering.
2.2L's Avatar
2.2L
how cute. Ok, im done.
Old Mar 9, 2006 | 06:33 PM
qtiger's Avatar
qtiger
Good. BTW, it is a header. The individual pipes are header pipes, primaries if they are between the engine and a collector, secondaries if between first and second collectors in the case of a 4-2-1 design.
