- Stroke Question
- manifold pressure with nos
- Hey everyone! New guy here, I'd like suggestions for my setup please... (56k warning)
- cv shaft question...
- Need help diagnosing black crap in exhaust!!
- Question about Wiring Harnesses!!
- K20 in 5th Gen Accord?!
- need suspension help bigtime!!!!!!
- shopping list
- Which one is better
- Engine Check Light ?
- First time at track with swap
- Anyone using HKS super AFR ???
- d15z1
- eek.... new fuel pump and some problems....
- Engine coolant temp sensor question?
- higher compression, stock ecu
- How do you measure the size of the collector on a header?
- Gas Mileage and Ignition timing relationship... Simple question...
- 90 integra manual conversion
- Burning Oil Smelly Problem???
- Engine Light
- B18a1 ecu in 5g civic?
- blow off valve makes an annoying squeeking noise!
- shift linkage question
- puting in a 94 ls b18b motor in a 93 ls.what do i need
- nitrous install
- safe mode ecu
- a/c install
- New goodies *Pix*
- Engine
- new to honduh (lol) building first hybrid
- sway bar specs??
- oil in coolant...solved
- Motor swap question
- MAP sensors
- building a dependable turbo/nos setup
- Injector cleaner - this stuff is the best!!!
- 1990 Legend CV boots
- Cams
- questions about emissions testing.
- how hard is swapping for a 1st timer?
- whats the real deal with lightened crank pulleys????
- Best way to replace rear motor mount bushing
- Prelude Dyno?
- ecu wiring help
- Next house will have this!
- looking for an ecu
- Place you bought your motor from, and how you like them.
- Need Help Asap!!!!
- Chicagoland import machine shop
- My New Spoons
- what kind of injectors are these???
- first gen b16a power?
- obd1 to obd2
- h23a nonVtec into 92 civic4dr
- turbo oil pan
- h22 torque
- High Compression---no cams
- Wheres all this piping going to?
- B18A1 into 94 Civic dx
- owned at the State ref, what a suprise :\
- turbo si help!!!
- crank scrapers
- Y8 Timing Info
- Torque Wrench Size????
- timing question
- Tutorial for DelSol Si Turbo
- Where can I buy a Right Hand Drive Integra/Civic/CRX
- Stumbling on decelleration
- Engine Codes
- quick simple question
- steps needed to turbocharge an LS
- I may have a bad IACV...
- F20A/F22A Hybrid
- Hybrid pictures
- Helms manual: 90-93 integra / Ls VTEC
- ACT clutch - need help + info pls ???
- Valve/piston clearance
- 99 civic si swap
- Been day-dreaming about this swap...
- Ls/vtec Hp
- Wanna do an engine, swap, but theres a problem
- clutch size for GSR PLEASE; size/specs of GSR clutch
- For those interested in the Golden Eagle Vacuum Manifold...
- scratchy sounds from car....
- ???What egt temp on turbo D16, in F*
- Nitrous Question
- question about hondamotors online
- Stock B18c1 throttle body size?
- B20/VTEC work in the bay area
- h22 VAFC
- Results of my D16Z6 compression test. Comments welcome
- www.jdmfaze.com - anyone know about this place?
- flywheel weight on b16?
- Engine Dimensions
- I have free access to...
- how much tranny fluid?
- Anybody have a '96-'98 SOHC non-VTEC (or any) engines left over
- Should I advance my ignition timing more or not?
- VTEC System malfunction- please help!
- Cel 14
- what does white smoke mean?
- engin help
- opinions on best cams/cam gear set up
- is this a good price?.....shortblock w/goodies
- Overheating! Responses quick please.
- Replacing Gsr pistons for ITR's
- My Civic likes to drink green Kool-Aid
- help! gsr pin out
- attn all you 4th gen STD or HF w/ swaps, i need your axles
- What exhaust system or muffler is the best out there?
- engine swap - gauge cluster problems
- d16y8 header options
- Rebuild Kits?
- usdmP13 ECU vs jdm P13ECU on a jdm h22a1 motor??????
- SAFC Throttle meter readings?!?!?!
- question regardin timing...
- 97 Civic Hatch w/GSR Engine and GSR Trans, shifter Question.
- NX jetting for a GSR
- Expected reasonable gains for boring out a D16Z6?
- pressure regulator Cut off solenoid valve?
- Need Help
- Need help from an axle genious!!!!
- prelude t/b on a civic??
- HYBRID Squad
- Coolant boogers
- Timing belt job -- the final autopsy [long]
- intake manifold
- boggin and backfiring
- Brake hardline question
- ruff idle and ruff run help ? please?
- Difference between ATR engine and...
- reoccuring pinging
- Piston Rings?
- B and D series alternators
- ZC DOHC Questions!
- what swap should i do on my EF hatch?
- Headgaskets
- brake swap FAQ???
- What do you guys think???
- ZC Engine (1.6 DOHC) questions
- O2 Sensor and OBD2 system - Also Titled "I Crashed The Car"
- starter problem i think
- help how to
- ls swap into a civic
- replacing head -- good idea? bad idea?
- intermittent low idle - mystery!
- Grounding Kits
- pulsating when sitting at vaccum 10
- my new car
- Jotech tuned 298 @15psi
- comptech or mugen???
- B20Z intake mani clearance issues
- JUN valve springs too stiff ??
- Erratic Idle.. PLEASE HELP
- stock exhaust diameters
- h22a with skunk intake mani
- b20 info needed asap
- HELP! Need ECU Codes for PR3.
- R tec coilover help
- octane vs. Emissions
- Will a jdm engine harness work with a USDM swap
- Need tech help w/ knocking
- info on the ls vtec
- ARPs for LS/VTEC? what to choose?
- a/c recharging?
- Ls Vtec
- I broke my radiator hose
- 98 Accord - build or swap????
- H23 & F22 question
- cold air intake in rain/snow
- Tdc Sensor
- Stroker Kit Question
- Turbo or Leave it Alone?
- MSD dist. CAP help!
- This may be a gay question
- more power
- my SOHC has a VERY notchy power band...normal?
- About my fuel pressure
- Question on boring and heads.
- Ls Vtec
- serious problem(i think)please help
- Ignitor question/Ignitor info, how it works?/MSD related HELP and Ignitor
- Door Panel Swaping
- b16 mount question???
- is there a dif????
- JDM H22 NO intake "Growl"....
- b16a1 from what car?
- O2 sensor question
- Transmission Question !! Please look !!
- H22 head F22 bottom?
- Cams
- Pistons
- Cranks
- Stupid Rotor!!
- Wow, Check out these SWEET blockguards
- D16A9 twin cam??
- check engine light and runing problem someone pleeeeeease help!!!
- Can the Idle Air Control Valve be adjusted/reset?
- sputter and stall
- Need help !!!
- thicker head gasket lower c/r?
- Carbon Fiber Valve Covers
- engine swap question...
- Girdle in HELMs manual
- obd2/obd1 b18c1 questions
- how is honda oil?
- Dont do This
- auto-manual
- 91 integra body swap
- engine
- what eletrical failure would cause......
- B Tranny Strength *OPINIONS*
- Twin Turbo for Integra?
- teh best valves and springs?
- i need help!!
- ecu symptoms
- MSD 6 SERIES <---don't like cold??
- Alternator replacement
- H22 on EBay
- K20 motor swap into 7th gen (2001-03) Civic EX, LX, DX Info In here
- N/A Fuel Management Q?
- 96 MC/booster
- B18c running Temp???
- Dynamic Compression Ratio
- b20 in a ef9 with 80 shot of nitrous
- AC relocator kit
- up displacement with out stroker kit?
- 92 civic shift problems
- c26 supra turbo?
- LS/VTEC harness and ECU ?
- Someone please clear up the wiring confusion!
- Cold Air Intake Question
- Weather/Rain affecting my transmission/clutch???
- 89 civic si and crx exhaust???
- How much to do a swap to a B series motor will do the labor my self
- i have no spark what else should i do?
- buying my hybrid tonight :)
- Msd Help Again!!!!!
- Civic ex fuel pump...sufficient??
- obd2 B18b into 92 CX?
- Header for B18??
- ITG Airbox
- Clutch question
- can anyone answer this question correctly?
- Msd Help!!!!!
- B16A block/GSR head?
- F22B1 in a Civic....problems?
- H22 overheating.
