Headgaskets
If I'm getting my engine bored out +0.5mm, then I'd want a larger bore headgasket as well, correct? Will it work with a stock headgasket?
Where's the best place for cometic gaskets? They make thicker ones, right?
Originally posted by rev
Head gaskets are designed to be used for an oversized bore already, so just use the one you get from the dealer/parts store.
http://www.nipponpower.com/engine/ga...ometic_hp.html
http://www.raceeng.com/ShowSuppliers...=IMP&subcat=GS
I was just curious.
