obd2/obd1 b18c1 questions
Old Apr 8, 2003 | 11:03 AM
v4lu3s's Avatar
v4lu3s
Default obd2/obd1 b18c1 questions
the car is a 96-97 civic hx, with an obd1 b18c1 and obd2 p72 ecu. using a p2p harness that is rewired to use teh obd1 injectors, alternator, and distributor.
we thought the ecu was a jdm ecu and would ignore the lack of CKF on the engine...turns out we were wrong.
i was wondering if anyone knew any tricks to get around the lack of ckf...BESIDES buying a new oil pump.
I am hoping there is someway i can wire up for signal from the distributor without having a real ckf on the car.
Old Apr 8, 2003 | 11:04 AM
qtiger's Avatar
qtiger
Nowhere in the manuals does it tell you what the signal type is.
Old Apr 8, 2003 | 11:08 AM
v4lu3s's Avatar
v4lu3s
damn i know it is a 3 wire sensor, i assume power, ground and signal...i really dont want to source a jdm ecu
