Transmission Question !! Please look !!
Old Apr 9, 2003 | 03:30 PM
Kenny's Avatar
Kenny
Default Transmission Question !! Please look !!
Hey everyone just wanted to start out saying thank you guys for helping..... I recently found a 96 gsr motor trans ecu for 950... The guy says the third gear grinds when shifting hard.... I was wondering if anyone knows what that is and if it can be fixed... Or do i have to just go get a new tranny ??? My friend had a 01 type R and it did the same thing just didn't know what it was.. Maybe a common problem with integra trannys ?? Is there a better trans i can put on the us gsr motor ? Thanks for your help BIG TIME !!!!
Kenny
Old Apr 9, 2003 | 03:45 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It's most likely the 3rd gear synchros. You can take it to a tranny shop and have it rebuilt, or open up the casing and do it yourself if you know your way around trannies. A used GSR/Si tranny usually goes for about $6-700 give or take. A used 4.40 R tranny is usually around $1200 and has shorter gearing and OEM LSD. A 4.785 R tranny is usually around $1500, and has even shorter gearing and also has OEM LSD. Any B series tranny will work with the longblock. If it's a hydro tranny, it'll bolt right on. If you want to run a cable tranny, you'll need to get the hydro>cable conversion kit that I believe either HCP or HASport makes.
Old Apr 10, 2003 | 06:57 PM
XSrcing's Avatar
XSrcing
the third gear grind is a common problem with gs-r's.
Old Apr 17, 2003 | 03:07 PM
91integrals's Avatar
91integrals
u r teh sux!!1!111!
my 3rd gear does it on my LS
maybe when i bought the new tranny i bought a gs-r trans...
