H22 overheating.
Old Mar 31, 2003 | 04:33 PM
zeebz23's Avatar
zeebz23
Default H22 overheating.
Hey I swapped an h22 in my accord and I still have a few sensors to wire up but I started and drove it to see how it ran and it overheats, I checked the water pump and thermostat, both good. And my f22 never overheated so i know the problem is with the H22 and not the radiator or something bolted to the car. Any idea if one of the sensors not hooked could cause it to overheat or does anyone have any suggestions as to what may be the problem??? Thanx
Old Mar 31, 2003 | 06:36 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Is your fan turning on?
Old Mar 31, 2003 | 07:38 PM
zeebz23's Avatar
zeebz23
Yeah, I have 2 electric fans, they both work.
Old Mar 31, 2003 | 08:54 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Are you getting any smoke at all? Is any coolant getting displaced from the radiator into the reservoir? If you say your thermostat and water pump are good, and your fans are working, then I would think it'd be the headgasket.
Old Apr 1, 2003 | 08:19 AM
qtiger's Avatar
qtiger
Probably just have air in your coolant system. Have you burped it?
Old Apr 1, 2003 | 12:13 PM
zeebz23's Avatar
zeebz23
How do I burp it?
Old Apr 1, 2003 | 08:03 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
run the engine with the radiator cap off or loose, and the heater blasting full-hot
Old Apr 1, 2003 | 10:22 PM
preylude99's Avatar
preylude99
yea, lets hope thats what it is and not the headgasket, good luck man i hope thats what it turns out to be...also, inspyral would prolly know the answer to this, does the f22 and h22 run at close to the same operating temperature or not? Cause you are using everything off the f22 right? even the thermostat? so say that the h22 stays a lil bit hotter then the f22 , this would cause this, unless of course the gauge is going ALL the way up. Is it just staying a lil too hot or is it going all the way up?
Old Apr 1, 2003 | 10:23 PM
preylude99's Avatar
preylude99
also, the sensors you are talking that you did not connect, was one of them the coolant temp sensor? or would he not be getting a reading at all?
Old Apr 1, 2003 | 10:49 PM
seth90dx's Avatar
seth90dx
You can take it to any "Tuneup" shop like a smog shop and they will "Flush" you coolant system. If that dont work would also sugest an aftermaket radiator. How close is the header to the radiator?
