how much tranny fluid?
Old Apr 23, 2003 | 06:46 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Default how much tranny fluid?
I have a y21 manual transmission out of a type-r. It is completely empty. How much fluid will it take to fill it to the right level?
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Apr 23, 2003 | 06:58 PM
qtiger's Avatar
qtiger
Couple hairs under 3 quarts.
Old Apr 24, 2003 | 12:03 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I usually just dump 3qt into the VSS hole if I'm too lazy to go under the car, but if you use the fill hole, it'll start spilling out(which is how you know it's properly filled) when you approach 3qt.
