Nitrous Question
Old Apr 25, 2003 | 08:16 PM
OptimusPrimer's Avatar
OptimusPrimer
Default Nitrous Question
Well anyways, I am new to the boards. So hello everyone.
Anyways, I have a question regarding a ricer in my area. He has an early 90's hatch with a 5spd, so I am guessing it is a 94 or so. Ok, so say he has a Si Hatch with 1.6 SOHC VTEC in it. How much can he possibly spray on his stock engine before he blows his engine?
Also, if it isnt the 1.6 SOHC VTEC, say it is just the base 1.5 engine, how much could he spray on the 1.5?
Thanks
Old Apr 25, 2003 | 09:11 PM
TypeRCivicEG6's Avatar
TypeRCivicEG6
I'm confused
If it is stock SOHC non-vtec........the most he can do is 50.......maby..........He should do more work on engine....like work on exhaust system and intake.......no point in spending money of it if your not doin more than 65 shot nitrous.....it can ruin the engine otherwise. The D16 models need to be worked on alot before adding nitrous. other wise you can screw up the engine. so spend money anything but nitrous and turbo.
Old Apr 25, 2003 | 09:13 PM
TypeRCivicEG6
I'm confused
Adding nitrouse on stock D16 is not good....Most you could do is maby 50 shot before ruining the engine.
Old Apr 25, 2003 | 10:55 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
what about on a DOHC ZC, stock internals, with Intake, Header, and Exhaust? could i handle 55 shot?
Old Apr 26, 2003 | 01:13 AM
drift's Avatar
drift
Flaccid Member
50 shot or 40% of your horsepower, whichever is less.
Old Apr 26, 2003 | 05:13 PM
TypeRCivicEG6
I'm confused
the dohc zc motor is pretty bad ass considering it has no vtec. i don't know much about it but it could prolly do up to 85 shot.
Old Apr 27, 2003 | 06:33 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
The biggest problem spraying on a honda isn't how much nitrous it can handle. The biggest problem is that people who want to use nitrous don't want to spend a lot of money and either use a single fogger dry system or a wet system. The reason this is a problem is because stock honda intake manifolds have an air bias problem that starves cylinder #3, which will fry the rings first if sprayed on frequently, or too high of a shot. If you want to spray often, or higher shots, direct port is your best option.
-Harry
AIM: NDcissive
Old Apr 27, 2003 | 06:51 AM
ZiviCase10287
RacinMasonC
i want dry shot, or is wet better?
Old Apr 27, 2003 | 07:31 AM
1stGenCRXer
For an occasional 50 shot, either. For spraying all the time on a stock manifold, direct port injection would be my choice over all others.
-Harry
AIM: NDcissive
Old Apr 27, 2003 | 03:42 PM
hlhiii's Avatar
hlhiii
if you are only going to run a 50 shot then d/p is not needed. i've been running a 75 shot (dry) on my b16 for 2 years without any problems. the only time that i would invest in a d/p set up is if i wanted to go over a 75 shot. make sure bottle pressure is good and keep an eye on the plugs and you should be fine.
