ruff idle and ruff run help ? please?
Tune up time buddy, lol spark plugs, plug wires, clean ur injectors, check ur air filter, change ur oil, gunk adatives work quite well, cap and rotor maybe, basic car maintance should do the trick if not then let us know and we'll try to find ur problem,
with surging idle check ur intake manifold for vacume leaks check the hoses for holes and cracks and make sure they are all still on correctly
well shit don't get all bent out of shape, if u want help you'll get suggestions, if u don't want to know our opinions don't post, or have already done stuff to fix ur problem try posting it. Fing Jack Ass fix it urself good luck buddy
Keep it civil, people.
He's probably angry because he offered perfectly valid points of advice, and got a :madfawk: in return. He suggested that you check for vacuum leaks, which is a possible cause for a fluctuating idle. In addition to that, I would make sure there isn't any air in your cooling system. If you don't have a vac leak, and your cooling system is bled, then I would check the IACV.
Originally posted by accordtuner
y u all angry? all i said was i done the tuneup jackoff
