HELP! Need ECU Codes for PR3.
Old Apr 14, 2003 | 06:33 PM
Darknight9's Avatar
Darknight9
Default HELP! Need ECU Codes for PR3.
Hey everyone
Im working on my 89 CRX equipped with a JDM B16A swap with the PR3 ecu. My car seems to idle and run ok but the vtec is inoperative. The check engine light has been on before but never affected the operation of the Vtec itself. Checked the malfunction indcator light on top of the ecu and it flashes this sequence
6 quick flashes - - - - - - then two long flashes ___ ___ then three short flashes - - - then it cycles back to the 6 short flashes again.
First question, is this code 6 and then code 3? If so, what does this identify as the issue? If it is not the above mentioned codes then what the heck are they? Any help that you can provide is much appreciated.
Thanks,
DK9
Old Apr 14, 2003 | 09:03 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Looks like a 6 and a 23 to me.
6 Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98
ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
23 Accord Civic CRV CRX Del Sol Odyssey Prelude
98 * 96-98 n/a n/a 94-97 n/a 92-98
KS (Knock Sensor)
* not a valid code if V-6 engine
