Motor swap question
Does anyone know if the motor from a 94 Integra will fit into an 93 Prelude? I have a totaled Integra and was going to buy a Prelude with a blown motor. Any help would be appreciated. Thanks
That would kinda of odd but i wont not see why it wouldnt you might have to mix match the mounts or use the teg mounts and not sure about the axle's but im sure that would be a eay fix if not custom as last resort
it can be done especially if u have still have the teg sitting around with all the parts, u might have low torque issues on the lude though cuz it is a lot heavier car. but who knows just a thought
You are going to run into some probablems with the shift linkage. Teg's use a bar while prelude use cable. Are you talking about a gsr motor or ls? Torque is going to severily lacking. Prelude's are not exactely light cars. If you have an ls motor your probably going to be unhappy with the performance in such a heavy car. You can pick up an h22a for pretty cheap if you are intrested in a prelude. Part out the teg and sell the motor
