boggin and backfiring
Old Apr 18, 2003 | 03:49 PM
accordtuner's Avatar
accordtuner
Banned
Default boggin and backfiring
ok guys, heres my big prob. my car sounds like its backfiring and bogging when at idle or whenever i cum to a stop. when u look at the engine and hear it it sounds normal and its not surgin or anything. but u can hear the backfiring and bogging cumin outa the exhuast. also the rpms fluctuate between 800 to 1000 back and forth then to 1200. i cleaned the iac and checked the fast thermo and all vaccum lines. what else could this be?????
thanks,
j
Old Apr 18, 2003 | 09:37 PM
MikeR's Avatar
MikeR
what do your plugs look like? this could be an indication of running rich or lean or have a cyl not firing correctly, there are any # of things that could cause it, do you have any codes etc..
Old Apr 19, 2003 | 01:15 AM
accordtuner
Banned
plugs r brand new, no cel at all. im thinkin maybe the fuel filter. ??? where is the fuel filter located on a 5th gen accord?
Old Apr 19, 2003 | 09:12 AM
accordtuner
Banned
anyone pls i need advice????!!!
Old Apr 19, 2003 | 12:39 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
You said the plugs are brand new, did you change the heat range of them?
-Harry
AIM: NDcissive
Old Apr 19, 2003 | 07:18 PM
accordtuner
Banned
wat u mean change the heat range of em? there ngk #2262 oem. arent those the only ones u can get for the 2.2 lx accord motor?
Old Apr 19, 2003 | 07:56 PM
1stGenCRXer
If you don't know what heat ranges are, it's probably a safe bet you didn't change it. Disregard my statement.
-Harry
AIM: NDcissive
Old Apr 20, 2003 | 05:53 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Maybe a bad o2 sensor?
Old Apr 20, 2003 | 07:10 AM
accordtuner
Banned
maybe an 02, im not getting any cel though.:naughty:
Old Apr 20, 2003 | 12:33 PM
preylude99's Avatar
preylude99
How many miles on the plug wires, dist. cap/rotor? Also, if it was a misfire in a cylinder the CEL would come on wouldnt it? My friend had the same problem and it ended up being a bad rotor inside the distributor cap, one side was kind of chipped on the rotor so check that out.....it shouldnt be too much to change the cap and rotor should it need those... also, the fuel filters are usually an all or nothing type deal, they either work or they are clogged, but you could change it should it be in an easy place to get to on your car, how many miles do you have on the engine?
