MAP sensors
Old May 2, 2003 | 07:00 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Default MAP sensors
I've got a GM 3-bar Map sensor right now for my turbocharger, and I'm going to be going back N/A. Will I need to rewire my old MAP sensor back in, or can I leave the 3-bar?
Old May 3, 2003 | 06:59 AM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
You need to reinstall the old map if you're running a stock chip, but you could have the ECM chipped for the GM sensor if you want - the only thing I found out is that the OEM honda sensors are more linear (accurate) than the GM sensor you have.
